diesel conversion
Topic: diesel conversion (Read 3488 times)
May 21, 2008, 05:52:59 pm
willymakit100
Newbie
diesel conversion
May 21, 2008, 05:52:59 pm »
what all do i need to convert a non diesel car to a non turbo diesel besides the engine.
May 21, 2008, 06:37:00 pm
TPW
diesel conversion
May 21, 2008, 06:37:00 pm »
A patient and forgiving wife.
May 21, 2008, 07:23:34 pm
subsonic
diesel conversion
May 21, 2008, 07:23:34 pm »
Quote from: "TPW"
You are a man of great wisdom :lol:
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
May 21, 2008, 08:59:51 pm
Turbinepowered
diesel conversion
May 21, 2008, 08:59:51 pm »
Quote from: "TPW"
So those of us with no girlfriend and no wife are golden?
May 21, 2008, 09:17:49 pm
flapjack
diesel conversion
May 21, 2008, 09:17:49 pm »
x3
what car & what motor you have in mind?
signature
May 22, 2008, 02:14:30 am
Ziptar
diesel conversion
May 22, 2008, 02:14:30 am »
Quote from: "TPW"
X 4 !!!
Well... sort of depends.
What engine do you want to swap into what vehicle?
I assume since you posted in the IDI forum area that you probably want to swap a diesel into an MKI or MKII?? Threads below will get you started.
Any one done gas to diesel?
Ziptar's Eco-Carat Project
85 Jetta engine swap
Project: 1.6 N/A going in a 94 Jetta GL 2.0L Gasser
May 22, 2008, 05:38:30 am
willymakit100
Newbie
swap
May 22, 2008, 05:38:30 am »
87 jetta and 1.9 non turbo like what came in it. and my wife isnt patient, guess i lose. also is the tranny the same as a gas?
May 22, 2008, 10:07:20 am
flapjack
diesel conversion
May 22, 2008, 10:07:20 am »
Get the trans code and compare here:
http://scirocco.org/gears/
signature
May 22, 2008, 04:10:34 pm
Dr. Diesel
Authorized Vendor
diesel conversion
May 22, 2008, 04:10:34 pm »
here's one item:
http://vwdiesel.net/phpBB/viewtopic.php?t=12727&highlight=gas
you'll have to put a glow plug system in too.
May 22, 2008, 06:03:48 pm
TPW
diesel conversion
May 22, 2008, 06:03:48 pm »
Here is my post on another website for my conversion that isn't done yet. The glow plug and fuel pump were easy to re-do.
http://www.motorgeek.com/phpBB2/viewtopic.php?t=17930
May 22, 2008, 06:59:55 pm
diesel conversion
May 22, 2008, 06:59:55 pm »
most of the trannys are the same as gassers, i would just put in the tallest one u can get your hands on, diesels have such a short power range, maybe like say 1000rpm-4000rpm, thats only 3k worth of usable power, long gears help it feel more like a gas car. since u can wind them out better.
Reply #11
May 23, 2008, 12:03:13 pm
914turboford
diesel conversion
Reply #11 on:
May 23, 2008, 12:03:13 pm »
From what I've been told any 4 cyl inline, liquid cooled VW engine, diesel or gas, will bolt to any 4 cyl trans, up to about '06 or so. The main things you need are a glow plug relay, which you can operate with a momentary switch, and a spin on fuel filter. Hook a wire to the IP that goes hot when the key is turned. I think that's about it.
Brian
diesel conversion
