Author Topic: Where to Buy a CHeap EGT Gauge  (Read 5370 times)
May 14, 2008, 05:26:03 pm
James8485
  • 223
« on: May 14, 2008, 05:26:03 pm »
i want to buy a EGT gauge for my car and i seen on here awhile back someone new a spot wher to get a digital one for like 40.00 or somehting
anyone point me in a good direction please!
---------James--------
Reply #1May 14, 2008, 06:09:07 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #1 on: May 14, 2008, 06:09:07 pm »
do you trust cheap gauges to accurately tell you what you'd like to know? :shock:
Reply #2May 14, 2008, 07:01:56 pm
James8485
  • 223
« Reply #2 on: May 14, 2008, 07:01:56 pm »
i have done the boost pin and putting a bigger turbo (k24)
a ball park would be fine as im not doing any extensive tuning
not touching the fuel screw just pin and turbo so i think a cheap one with safice
Reply #3May 14, 2008, 08:56:18 pm
flapjack
  • 283
« Reply #3 on: May 14, 2008, 08:56:18 pm »
i got this one
http://www.egauges.com/vdo_mult.asp?Type=Pyrometer&Series=Vision&Units=E
with this probe:
http://www.aircraftspruce.com/catalog/inpages/micro8egt.php
there were lots on ebay for less money when I was looking.
What turbo do you have now? If you're not going to add fuel, why a bigger turbo? seems like you'd just be adding lag?
signature
Reply #4May 14, 2008, 11:31:18 pm
James8485
  • 223
« Reply #4 on: May 14, 2008, 11:31:18 pm »
i have added the 1.6TD pin and i have a K03 currently and with the pin even on a less steep side she smokes quite i bit as its pumping more fuel than the "small" K03 can match for air......
it only smokes on hard acceleration and not on regular driving so i didnt think i would need one but when changing to a slightly biggger turbo and adjusting the pin more my ETGs might go up and want to monitor them..
i have heard that just doing the pin and turbo makes the car way better and faster to drve "for a diesel"!
Reply #5May 15, 2008, 04:01:02 am
gigaz2
  • 626
« Reply #5 on: May 15, 2008, 04:01:02 am »
back off a bit on max fuel, or increase turbo pressure.
why would you want a bigger turbo on a daily driven car?
I have a K24 and it feels like a 1.6D until that big brute wakes up.
after driving a small garrett T2 intercooled golf I immediately bought a smaller turbo.
its what a turbodiesel should be, no lag, just power
Reply #6May 15, 2008, 06:22:39 am
« Reply #6 on: May 15, 2008, 06:22:39 am »
I have a Glowshift EGT gauge, which for fairly inexpensive, seems fairly accurate according to someone else who tested theirs. It reacts fairly quickly as well.
Reply #7May 15, 2008, 01:56:16 pm
James8485
  • 223
« Reply #7 on: May 15, 2008, 01:56:16 pm »
Well i bought a "glowShift" EGT gauge today and cant wait for it to arrive as thats all im waiting for to do the swap also i was just going to cut the DP at where it curvers after the flex part and then hack the flange off and weld my new adapted one that mates to the turbo and then just buy a piece of pipe to join them in the middle? sound good?
anywways thanks for the advice on the EGT gauge Jimfoo i looks sweet and its 110.00 to the door and thats with the probe! you gotta watch alot dont come with that its extra!
Reply #8May 15, 2008, 03:21:54 pm
KTZed
  • 170
« Reply #8 on: May 15, 2008, 03:21:54 pm »
+1 For Glowshift. Hope you didnt get the tinted one cause you wont be able to see it during the day.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #9May 15, 2008, 08:54:53 pm
James8485
  • 223
« Reply #9 on: May 15, 2008, 08:54:53 pm »
haha i think i did but my boost gauge is tinted and i hooked it up so it used the accesory power from the cd player so when my ignition is on i have to power to it.
no problem seeing it when its lit up
you must have hooked yours up through your lights correct?
Reply #10May 15, 2008, 09:46:24 pm
« Reply #10 on: May 15, 2008, 09:46:24 pm »
Nope, you can't see them as the tinting is too dark compared to the light's brightness unless you have tinted windows. Sunlight makes it impossible to see. I forgot to mention this as I also fell victim. I ended up making a new "lens" out of a piece of CD case.
Reply #11May 16, 2008, 03:07:52 am
James8485
  • 223
« Reply #11 on: May 16, 2008, 03:07:52 am »
well windows are 2 1/2 percent all the way around very dark so hopfuly i can see the stupid thing! if not will do that cd case idea
Reply #12May 16, 2008, 04:55:42 am
hamradio
  • 282
« Reply #12 on: May 16, 2008, 04:55:42 am »
I bought a digital one from 'auber instruments' for $35 and a k type thermocouple for $6.
