Author Topic: operating cruise control  (Read 3820 times)
April 22, 2008, 03:06:31 pm
vegfuel
  • 125
« on: April 22, 2008, 03:06:31 pm »
My 86 Golf has what looks like a button under the accelerator pedal. It's not the high beams either. Does anyone know what this could be? I thought it was the cruise control but if it is how do you work it with out taking your foot off the pedal?
1986 Golf WVO converted.
Reply #1April 22, 2008, 03:17:18 pm
« Reply #1 on: April 22, 2008, 03:17:18 pm »
If you are talking about the thick black plastic piece it is a pedal stop
Reply #2April 22, 2008, 08:53:36 pm
vegfuel
  • 125
« Reply #2 on: April 22, 2008, 08:53:36 pm »
ok but how does the cruise control usaully work on these? I can't really figure it out from my manual.
Reply #3April 23, 2008, 05:11:18 am
« Reply #3 on: April 23, 2008, 05:11:18 am »
Quote from: "vegfuel"
its on the signal arm.  near the end theres a switch to turn it on/off and i believe resume.  the end button is pressed once you've reached the speed you want (and the cruise button has to be set to on at this point)  it should work unless theres a vacuum leak somewhere in the system.
