K-24 & T3?
Topic: K-24 & T3? (Read 4650 times)
April 19, 2008, 12:14:04 pm
Torchd
K-24 & T3?
April 19, 2008, 12:14:04 pm »
Whats the difference between a Garett T3 and a KKK k24?
Which one is better?
Both of them originally came with the 1.6TD in MKIIs and both the turbos put of the same horsepower and both have same size... so which is better, any pros and cons of the two?
April 19, 2008, 12:38:08 pm
g-spec
K-24 & T3?
April 19, 2008, 12:38:08 pm »
I dont have first hand experience....but I have heard that the T3 is a little better.....I dont know the specifics!
April 19, 2008, 05:27:19 pm
rallydiesel
K-24 & T3?
April 19, 2008, 05:27:19 pm »
A con of the k24 is that the wastegate may seize up.
1991 Jetta TD - sold
2001 Golf TDI - Son's
April 19, 2008, 06:04:33 pm
K-24 & T3?
April 19, 2008, 06:04:33 pm »
t3 is bigger especially on the exhaust side, and like its been said, the k24 likes to seize up
April 19, 2008, 06:37:59 pm
blkboostedtruck
K-24 & T3?
April 19, 2008, 06:37:59 pm »
the boys say here that the k24 spools better but the T3 is a little more robust!
i'm runnin a K24 at 21PSI. so far no problems ? knock on wood :roll:
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
April 19, 2008, 09:00:49 pm
Torchd
K-24 & T3?
April 19, 2008, 09:00:49 pm »
hmm seen!!
so how can i tell if the wastegate on the K-24 has seized up?? and whats the fix?
April 21, 2008, 03:25:18 am
Torchd
K-24 & T3?
April 21, 2008, 03:25:18 am »
Guys!!
anyonee??
April 21, 2008, 03:35:52 am
stewardc
K-24 & T3?
April 21, 2008, 03:35:52 am »
Quote from: "Torchd"
and whats the fix?
Why install a T3, of course. :roll: Seriously, I've never heard of a wastegate seizing on a diesel, but tha discussion points are all true. The T3 makes a little better power on the top end.
April 21, 2008, 04:41:48 am
spencebm
K-24 & T3?
April 21, 2008, 04:41:48 am »
the t3 will wont make full boost till 3K rpm
Ben Spencer
April 21, 2008, 08:31:09 am
K-24 & T3?
April 21, 2008, 08:31:09 am »
Which is better... Pepsi or Coke ?? :wink:
Both turbos work fine. Both are slower to develop boost than their smaller cousins like the K14 but both have a bit more top-end omph in exchange.
VW treated them pretty much interchangeably and in my opinion so can you... find a good one, install it, and move on to other concerns !!
April 22, 2008, 02:37:39 am
Torchd
K-24 & T3?
April 22, 2008, 02:37:39 am »
That you all for the replies!
Yeha Vince is right, MkII drivers always have other bigger concerns to worry about!
Reply #11
April 22, 2008, 04:25:08 am
foxracer1
Authorized Vendor
K-24 & T3?
Reply #11 on:
April 22, 2008, 04:25:08 am »
Quote from: "spencebm"
I hope your not using mine as a way of gauging that. It has a leak before the turbo in the exhaust somewhere.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #12
April 22, 2008, 06:19:48 am
subsonic
K-24 & T3?
Reply #12 on:
April 22, 2008, 06:19:48 am »
Look up the a/r of both and the trims.
Reply #13
April 22, 2008, 11:58:16 pm
Torchd
K-24 & T3?
Reply #13 on:
April 22, 2008, 11:58:16 pm »
Whats a/r how do i find that out and whats trim?
Reply #14
April 23, 2008, 05:42:44 am
subsonic
K-24 & T3?
Reply #14 on:
April 23, 2008, 05:42:44 am »
I am not a turbo guru, but these guys are
Read on.
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech101.html
You can also go to the faq section and there are some links to turbo maps.
K-24 & T3?
