Author Topic: oil in coolant '89 Jetta diesel  (Read 2051 times)
April 11, 2008, 08:42:31 pm
briandownunda
« on: April 11, 2008, 08:42:31 pm »
I have found oil in the coolant in the expansion tank.  Can I assume that this is from a bad head gasket or is there another way for this to happen ?  How harmful is this ?
Thanks in advance !
Reply #1April 11, 2008, 08:54:51 pm
« Reply #1 on: April 11, 2008, 08:54:51 pm »
Two other possibilities:
- crack in the block between an oil gallery and the coolant passages
- if your car is a turbo it has an water/oil heat exchanger... they can develop leaks
Compression test and/or leakdown test is a good next step if you don't have the water/oil heat exchanger.
