Author Topic: What turbos are u running on your AAZ?  (Read 13184 times)
March 30, 2008, 12:17:06 pm
numbnuts
  • 99
« on: March 30, 2008, 12:17:06 pm »
Hi, just got hold of a mk3 golf TD with what i presume is an AAZ, its a 96 btw. The pull leaves alot to be desired, seems like alot of difference from my last mk2 gtd. So i was wondering what turbos are u guys running? What are they off? and what other parts do ui need to fit aswell? Nothing too pricey though :lol:
Thanks Joel
Reply #1March 30, 2008, 12:54:43 pm
bert
  • 423
« Reply #1 on: March 30, 2008, 12:54:43 pm »
The AAZ is flat as a fart bert,put a rover 220TD aneroid pin in ASAP this will help to be honest,im using a garrett T3 off a 1.6 TD mk2 golf,goes like stink to be honest,ive only swapped the pin,NO other mods at all.
Bert
Reply #2March 30, 2008, 01:03:13 pm
James8485
  • 223
« Reply #2 on: March 30, 2008, 01:03:13 pm »
no adjusting to fuel?
did you do the pin yourself?
does the pin just alow more fuel when in boost???
---------James--------
Reply #3March 30, 2008, 01:05:32 pm
  • 5104
« Reply #3 on: March 30, 2008, 01:05:32 pm »
the pintakes like 30 seconds to change, its only 4 screws.
Reply #4March 30, 2008, 01:07:01 pm
numbnuts
  • 99
« Reply #4 on: March 30, 2008, 01:07:01 pm »
HIya Bert, i remember u said before about that pin, i will have to look out for 1 in a scrappy, but i don't have much time on my hands atm :roll:
Will i need the manifold aswell or will it fit onto the AAZ? Any other bits?
Reply #5March 30, 2008, 01:07:54 pm
stewardc
« Reply #5 on: March 30, 2008, 01:07:54 pm »
I'm using a T3 and a Giles pump  :D  :shock:  :D
Reply #6March 30, 2008, 01:12:01 pm
James8485
  • 223
« Reply #6 on: March 30, 2008, 01:12:01 pm »
this may be already up here somewher but can i damage my pump at all by doinbg this mod (pin) or make the pump not last as long?
may be a dumb question but i have no idea..
it also says you get better fuel millage..i dont get it more fuel= beter millage?? got me!!!!
thanks for the help
Reply #7March 30, 2008, 01:19:39 pm
numbnuts
  • 99
« Reply #7 on: March 30, 2008, 01:19:39 pm »
hmm, is there anyone over here in the uk that can rebuild the pumps like giles does? :?
Reply #8March 30, 2008, 01:23:02 pm
bert
  • 423
« Reply #8 on: March 30, 2008, 01:23:02 pm »
Hi,i have not touched the fuel screw,the governor springs,nothing exept the aneroid pin,took 3 mins to swap,look at the top of the pump the 4 screws come out,the pin pulls out with the diaphram,leave the spring where it is,slide the rover 220Td pin in,4 screws and off you go,i took a diesel lover for a spin and it scared him  :lol:  he was amazed how a 1.9TD can go so quick  :twisted: And it dont adjust the off boost fueling either (rover pin ground equal not offset so just put it in)
Bert
Reply #9March 30, 2008, 01:29:05 pm
bert
  • 423
« Reply #9 on: March 30, 2008, 01:29:05 pm »
Joel,i used the 1.6TD manifold aswell,just bolts on,i used the 1.9 inlet manifold as no blow off valve required  :roll:  had to cut a little piece of alloy off the manifold for the turbo to fit as its bigger.
it is a great car now,just lowered the back as it was way high  :?
from this
to this
Bert
Reply #10March 30, 2008, 01:30:44 pm
numbnuts
  • 99
« Reply #10 on: March 30, 2008, 01:30:44 pm »
Just thought, there is that viking rover spares just down the road from me :lol:
Will have to pay them a visit :twisted:
Reply #11March 30, 2008, 01:32:33 pm
bert
  • 423
« Reply #11 on: March 30, 2008, 01:32:33 pm »
yes viking,you need about an N reg rover 220 or 420 TD with the bosch pump,the later were fly by wire  :(
Bert
Reply #12March 30, 2008, 01:33:35 pm
numbnuts
  • 99
« Reply #12 on: March 30, 2008, 01:33:35 pm »
Bert, do u need any mk1 bits as i am clearing out the garage at the mo. What brakes are u running? I have the gti stuff if u need it and also a nicwe intercooler that i am sure would fit infront of the rad u have. It was to small in the gtd
Reply #13March 30, 2008, 01:41:16 pm
bert
  • 423
« Reply #13 on: March 30, 2008, 01:41:16 pm »
what you want for the bits? what you got? ive got 2 mk1 golfs so spares always hoarded  :wink: i need an intercooler really too,what car you got i cant remember?
we need to meet up when its taxed in may and i take you for a rasp  :twisted:
Bert
Reply #14March 30, 2008, 01:54:30 pm
numbnuts
  • 99
« Reply #14 on: March 30, 2008, 01:54:30 pm »
THe parts were off the mk1 gti 1.8, now nearly a 16v g60 with 6 speed :twisted:  I forget what the intercooler is off i bought it ages ago but i think it'll fit. What rad are u running? I seem to remember the intercooler fit infront of the 16v rad i was gonna use, so if its not wider than that 8)
Also have a spare gtd gearbox and might be able to scrape together the inkage needed to convert a 4 speed to 5 8)
