Author Topic: What turbos are u running on your AAZ?  (Read 13158 times)
Reply #15March 30, 2008, 02:12:52 pm
burnt_servo
  • 278
« Reply #15 on: March 30, 2008, 02:12:52 pm »
you can also just grind the fuel pin ... it's a very popular mod with the older dodges with  cummins that use the ve pump .....
check out this thread , about 1/2 way down .
http://vwdiesel.net/phpBB/viewtopic.php?t=13182&highlight=
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #16April 01, 2008, 04:45:02 am
numbnuts
  • 99
« Reply #16 on: April 01, 2008, 04:45:02 am »
So its the 1.6 td T3 i should be looking out for then?
Reply #17April 01, 2008, 11:44:51 am
stewardc
« Reply #17 on: April 01, 2008, 11:44:51 am »
Quote from: "numbnuts"
Yessir, that's the one.
Reply #18April 01, 2008, 11:49:05 am
raf_construct
  • 5
« Reply #18 on: April 01, 2008, 11:49:05 am »
You can also find a k24 from a mk2. They are a bit better than the T3 at higher boosts.
I am custom fitting a GT1749 to my 2.1 AAZ engine. Will post any feedback here when it's running.
Reply #19April 01, 2008, 11:52:02 am
stewardc
« Reply #19 on: April 01, 2008, 11:52:02 am »
Quote from: "raf_construct"
Beg to differ here. I tried em both and the T3 is the answer. Now to button down the hatches for the innevitable flamers. :roll:
Reply #20April 01, 2008, 01:31:34 pm
James8485
  • 223
« Reply #20 on: April 01, 2008, 01:31:34 pm »
i just gots a k24 and intalling it in the next couple days! what wrong with the k24 i heard its an awsome turbo perfect size spools up good and has good boost
whats the diffenence between the 2?
---------James--------
Reply #21April 01, 2008, 02:20:36 pm
raf_construct
  • 5
« Reply #21 on: April 01, 2008, 02:20:36 pm »
They are practically the same, they are both very good at handling high pressure. If both were to be pushed to the limit, the T3 usually breaks down just a bit faster. However, not many take it that close to the limit.  :wink:
Reply #22April 01, 2008, 02:44:25 pm
bert
  • 423
« Reply #22 on: April 01, 2008, 02:44:25 pm »
the garrett parts are easier to get hold of...........
my garrett T3 is an amazing piece of kit,well pleased with the spool up and the boost  :wink:
Reply #23April 01, 2008, 03:26:56 pm
James8485
  • 223
« Reply #23 on: April 01, 2008, 03:26:56 pm »
the T3 isnt the same triangular flange as the the aaz K03 is it>>>
i went and got a k24 b/c i could find any good turbo to direct bolt
Reply #24April 01, 2008, 11:56:02 pm
Torchd
  • 372
« Reply #24 on: April 01, 2008, 11:56:02 pm »
Which car/engine were the following turbos originally fitted on?
K03
K14
Garrett T3
K24??
Reply #25April 02, 2008, 02:30:44 am
ChopSauce
  • 514
« Reply #25 on: April 02, 2008, 02:30:44 am »
Quote from: "Torchd"
K03
K14
Garrett T3
K24??
In France
K03     ->                AHU, possibly 1Z (1900 TDI) (1)
K14     ->                two models - small (2) on RA/SB (1600 TD 80 ch) - larger on AAZ (1900 TD)
Garrett T3    ->       JR (1600 TD 70 ch)
K24        ->             JR and similar (1600 TD 70 ch) engine on Mk1
 _
(1) Only the K03 and the GT15 turbos seem to have that triangular "bolting pattern" - on the exhaust manifold, while the other turbos above seem to have the same (T3-like) bolting pattern
(2) The "small" K14 appeared to be (sometimes) replaced by a T2 - same as K24/T3 - note : there seem to be more T3 and K14 here
Reply #26April 02, 2008, 11:06:04 pm
Torchd
  • 372
« Reply #26 on: April 02, 2008, 11:06:04 pm »
Thanks for the info ross!!!
So which turbo will i have on my cars??
MKII, 1989, 1.6TD.. Engine MF.
MKIII, 1996, 1.9TD.. Engine AAZ.
Reply #27April 03, 2008, 01:16:38 am
ChopSauce
  • 514
« Reply #27 on: April 03, 2008, 01:16:38 am »
You're welcome, but I do not know anything about the MF engine (only JR & RA/SB). How many Hp(ch) is it ?
80 ch is either equipped with a T2 or K14 - most likely watercooled, otherwise that is T3/K24 - normally. If it is 1989 it is probably a JR - with a T3. Is the turbo a Garrett ?
 ... and, er ... I thought that was written above: the AAZ is normally equipped with the larger - oilcooled - K14.
As far as I know all that is written on the turbos - but the nature of the cooling ... of course
Reply #28April 03, 2008, 04:04:00 am
raf_construct
  • 5
« Reply #28 on: April 03, 2008, 04:04:00 am »
Later AAZ engines can also have a k03 turbo. Usually combined with an EGR system.
At least in Europe this is.
RA/SB engines can have a non-watercooled turbo as well. This is mostly the k14 I believe. Haven't seen them with the bigger k24 / T3 turbo's yet.
Watercooled turbos are the k14/6 and the garret T2.
Reply #29April 03, 2008, 04:24:50 am
Torchd
  • 372
« Reply #29 on: April 03, 2008, 04:24:50 am »
John its a 70 hp engine...  and the turbo is by KKK
Quote from: "JohnRoss"
