Author Topic: some Tiny-Tach pictures  (Read 11255 times)
March 23, 2008, 08:11:46 pm
« on: March 23, 2008, 08:11:46 pm »
I promised y'all some pictures as I experiment with the Diesel Tiny Tach.  If you just joined our broadcast, it's a digital tachometer with a transducer that bolts to an injector line... no W terminal needed.  It acts like a tach but also has two service interval timers, a max RPM readout, and reverts to an hour meter automatically when the engine is off.
The display looks like this:
(yes my idle is a bit high... it's either that or I lose a filling)
The transducer bolts to an injector line with two small hex head machine screws.  In this picture I've bolted on another terminal (bright pink) so that I can attach an oscilloscope probe:
Here's the output signal from the transducer at about 1100 RPM for all you geeks out there:
It's a pretty typical piezo transducer signal... a damped oscillation with amplitude about 60V and a period of 27 mS (37 Hz)...at this RPM... once per every two revolutions as injector #1 fires.
37 Hz / 2 * (60 seconds per minute) = 1110 RPM... cool dat.
It is a nice strong stable pulse, so the next step is to develop an interface circuit so that it can drive a standard timing light.   With the right multiplier circuit it should be able to drive a gasser or diesel  tach just fine as well.
The price for the entire unit has gone up 30 bucks since I bought this one, but the tranducer alone is still evidently quite affordable, particularly if it can become a timing light as well.
Other observations:
- the display is a good size and is backlit at all times
- having said that, the display is not really flush-mountable on the dash without wires showing etc.  Not really an automotive form factor.
- the display has a pretty fast update rate (half a second or so) so great for monitoring RPM, setting the idle and max speed, etc... but probably too slow IMHO for shifting
Will post again when I have some circuitry developed.
Reply #1March 23, 2008, 09:22:58 pm
« Reply #1 on: March 23, 2008, 09:22:58 pm »
Cool! Thanks for the info.
Reply #2March 23, 2008, 09:54:11 pm
diesel smoke
  • 209
« Reply #2 on: March 23, 2008, 09:54:11 pm »
Neato!, did you get that in Edmonton somewhere or did you order it? Off the site its rather pricey-$95+shipping.
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #3March 23, 2008, 10:35:02 pm
« Reply #3 on: March 23, 2008, 10:35:02 pm »
Quote from: "diesel smoke"
There's a Canadian distributor in Markham.... Forster Instruments.  They warned me the price was about to go up.. I got mine for $65 + shipping... and I guess they were right  :cry:
Reply #4March 23, 2008, 11:20:09 pm
« Reply #4 on: March 23, 2008, 11:20:09 pm »
i wonder if you bought 4 transducer's if you could detect any injectors that are late in opening?  that is a really neat option for those without tach's!
Reply #5March 24, 2008, 06:10:51 am
saurkraut
  • 904
« Reply #5 on: March 24, 2008, 06:10:51 am »
Ho, make a gas tach conversion kit!  I'll be your first customer for 2 Ea!
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6March 24, 2008, 08:31:15 am
« Reply #6 on: March 24, 2008, 08:31:15 am »
Yeah, if you can just buy the transducer by itself for $35.00, and have a plug-n-play module to attach to your tach of choice, that would be the berries!  Much better than farting around modifying stock tachs.  You think Dakota digital would have an adapter gizmo to convert a transducer signal to something a tach could use?
Reply #7March 24, 2008, 09:43:50 am
« Reply #7 on: March 24, 2008, 09:43:50 am »
Quote from: "jtanguay"
Interesting, if perhaps a bit pricey !
The ability to "see" when an injector fires brings on all kinds of interesting possibilities.
My first experiment will be to temporarily install a 135 bar injector in #4 for a few minutes (the rest are 155 bar).  By comparing #1 and #4 we'll then know *exactly* how much the ignition is retarded by a 20 bar difference in breaking pressure.
So much to do... so little time !!
Reply #8March 24, 2008, 10:29:41 am
« Reply #8 on: March 24, 2008, 10:29:41 am »
Quote from: "lord_verminaard"
Hmmmm.... they might.  It will need to be a 4X multiplier rather than a 12X divider but ya never know.
Having said that, if they do have something it will probably be the better part of 100 bucks or so.   I'm gonna restrict myself to parts found at your friendly neighborhood Radio Shack / The Source since they are pretty ubiquitous,  and see if I can do it for 10.
Reply #9March 24, 2008, 11:42:25 am
saurkraut
  • 904
« Reply #9 on: March 24, 2008, 11:42:25 am »
Go nuts Vince!
I'm down for two.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #10March 24, 2008, 06:36:36 pm
somepunk22
  • 79
« Reply #10 on: March 24, 2008, 06:36:36 pm »
+1
Reply #11March 24, 2008, 07:30:50 pm
diesel smoke
  • 209
« Reply #11 on: March 24, 2008, 07:30:50 pm »
Quote from: "Vincent Waldon"
Vince,
If you want a good place for electronics go to Active Electronics, there in Edmonton. 6029-103rd St.(Gateway Blvd) 438-0644 8)  :D
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #12March 24, 2008, 10:08:46 pm
« Reply #12 on: March 24, 2008, 10:08:46 pm »
Excellent call dude... one of my shrines actually... along with Princess Auto and Lee Valley Tools.  One of those stores you walk into and want to say "I'll take one of everything my good man".  :wink:
However, not everyone has an Active Electronics in their neighborhood so I'll try to stick to parts from Radio Shack.... make 'em easier to source for the wide assortment of diesel folks out there ??!
Reply #13March 24, 2008, 10:13:08 pm
« Reply #13 on: March 24, 2008, 10:13:08 pm »
Quote from: "libbybapa"
I assume you're also going to work out the details for a loop to run a strobo timing light, right Vince?   :D
That's the plan... hacking the timing light pickup is just too crude... and some of us still have gassers to attend to every now and then. :cry:  Spark plug... what's a spark plug ?! :roll:
You have a timing adapter right ??  Is your's a looper or a glow plug gazer ??
Reply #14March 24, 2008, 10:33:42 pm
  • Online
  • 2931
« Reply #14 on: March 24, 2008, 10:33:42 pm »
I want to use something like this as an input to a computer.
 Another input from a mark on the flywheel and I could watch the timing on a computer.... record/tune the advance curve.
