Author Topic: Total seal Quickseat  (Read 3442 times)
March 10, 2008, 12:42:33 pm
subsonic
  • 1836
« on: March 10, 2008, 12:42:33 pm »
Thinking about buying some.  Whats the best price you have found for it, and where did you get it?
Reply #1March 10, 2008, 03:21:22 pm
dillenger1
  • 777
« Reply #1 on: March 10, 2008, 03:21:22 pm »
Is it true that you can "use baking soda in a pinch"?Ive heard of cleaning"comet" type powders also.What is the real stuff,chemically?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2March 10, 2008, 03:39:14 pm
« Reply #2 on: March 10, 2008, 03:39:14 pm »
i got some right from total seal.  it's not expensive for what it 'can' do.  (quickly seating rings is not a bad thing...  :wink: )
i think it was around $10-20 bucks??? call and find out
Reply #3March 10, 2008, 03:56:13 pm
  • 1739
« Reply #3 on: March 10, 2008, 03:56:13 pm »
As far as i understand it, the powder is just there to tell you when the walls are 100% oil free. In theory if you are methodical about cleaning and drying them you should be good to go . Remember the idea is to run the rings in dry. Maybe that's why comet would work, as it would change color if there was any moisture.
Reply #4March 10, 2008, 05:46:07 pm
« Reply #4 on: March 10, 2008, 05:46:07 pm »
I would not put comet in an engine. Chlorine does bad things to all metals and oil as well.
Reply #5March 10, 2008, 07:05:47 pm
Vanagoner
  • 219
« Reply #5 on: March 10, 2008, 07:05:47 pm »
"Bar Keeper's Friend" cleanser might work better- no chlorine. The Oxalic acid removes rust (H2 C2 O4-2H2O) and wouldn't hurt aluminum, like caustics I think.
Sage
'82  Vanagon Westy, the mighty N/A
Reply #6March 10, 2008, 08:18:58 pm
  • 1739
« Reply #6 on: March 10, 2008, 08:18:58 pm »
yeah certainly wasn't an endorsement. just get it dry.
Reply #7March 11, 2008, 01:10:22 am
« Reply #7 on: March 11, 2008, 01:10:22 am »
if you want to get it dry use some of that orange cleaner crap.  the best degreaser i've ever seen that is practically harmless. (unless swallowed of course  :roll: )
Reply #8March 11, 2008, 12:29:21 pm
subsonic
  • 1836
« Reply #8 on: March 11, 2008, 12:29:21 pm »
So are you guys saying that this stuff just shows moisture on the cyl walls?
