Author Topic: oil feed tube broken!!  (Read 7814 times)
April 12, 2005, 06:09:28 pm
Hammy
  • 169
« on: April 12, 2005, 06:09:28 pm »
Anyone here had their turbo oil feed tube break? Mine did, and it pumped all the oil out. I noticed it before the oil light or the oil pressure gauge dropped. Seems to run okay still. Looks like a ten minute job to replace. But, has anyone repaired with neoprene line, instead of the steel? I was thinking that this might be better for the vibration factor. Or does anyone have a good source to find a new tube, or used?
Thanks in advance;
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #1April 13, 2005, 03:37:54 am
Patrick
  • 1034
« Reply #1 on: April 13, 2005, 03:37:54 am »
You could do a patch job with neoprene, but I wouldn't want to leave it that way. IF the fittings are teh same, there's lots of turbo feed lines on cummins engines made from braided steel that would work well AND look great. The other possibility (besides the dealership) is regular hydraulic hose made to order IF you can match the fittings. Good luck! let us know what you come up with. I've got one I dread the thought of taking off, loos like it will give me trouble when I do!
Reply #2April 13, 2005, 09:54:51 am
chrissev
  • 694
Re: oil feed tube broken!!
« Reply #2 on: April 13, 2005, 09:54:51 am »
Quote from: "Moonstone"
Thanks in advance;
avoid the dealership at all costs.  Those tubes are expensive.
Reply #3April 14, 2005, 06:39:27 am
Hammy
  • 169
« Reply #3 on: April 14, 2005, 06:39:27 am »
I just priced out a tube at the dealer, they want $60. I think that is reasonable. They used to be near $200! I got a used one for $10 8) , but I think I'm gonna get a new one and save the used one for a spare.  :)
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #4April 14, 2005, 12:22:20 pm
fspGTD
  • 1529
« Reply #4 on: April 14, 2005, 12:22:20 pm »
Make sure to install it using those Adel-style rubber-cushioned support clamps, so it doesn't vibrate and flex too much (which I'm guessing is what caused yours to crack?)
Although more supports would be better, on my 1.6lTD I have done away with the support near the intake manifold "El", and am just relying on the support near the water neck on the side of the cylinder head.  (Reason I did away with the intake manifold oilline support is I routed a boost tube in that area.)
Jake Russell
Reply #5April 14, 2005, 01:52:22 pm
veeman
  • 421
« Reply #5 on: April 14, 2005, 01:52:22 pm »
Jake... Do you mean clamps like this?
Where is the hose normally supported?  Mine was disconnected when I got my motor...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #6April 14, 2005, 02:06:43 pm
fspGTD
  • 1529
« Reply #6 on: April 14, 2005, 02:06:43 pm »
Yes exactly.  In a factory 1.6lTD there are 2 adel-style clamps holding the turbo oil supply tube: one bolts to the top fastener that holds the water neck to the transmission-end of the cylinder head.  The other bolts to a heat shield near the "El" that's on top of the intake manifold.
Here you can see the top one near the intake "El":
Here you can see the side one near the water neck:
Jake Russell
Reply #7April 14, 2005, 02:10:24 pm
veeman
  • 421
« Reply #7 on: April 14, 2005, 02:10:24 pm »
Thanks Jake...
No wonder I didn't recognize those clamps for that pipe.  I didn't get that one with the engine.  I guess I'll add that to the "wish" list.  I was thinking of  the drain pipe that's on the backside of the motor...the one that essentially looks like two metal pipes with a metal braided section in the middle.
81 Caddy TD
83 VW GTI FSP
86 4ktq
Reply #8April 15, 2005, 03:42:44 am
Rat407
  • 289
« Reply #8 on: April 15, 2005, 03:42:44 am »
I had a leak at the connection that I couldn't stop, got my new line at the dealer, I think I paid $30, anyway the leak stopped and it is a nice tight fit. Then I find out that a local truck repair shop makes custom hoses and tubing and could have made mine.  So look around and check out all the heavy truck repair shops as well as any farm equipment shops, possibly John Deere and such.
Oh those clamp are great and I use them all the time on other things as well. :D
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #9April 17, 2005, 03:40:22 pm
Baxter
« Reply #9 on: April 17, 2005, 03:40:22 pm »
When I did my TDI swap into a T3 I used all sorts of parts, there was no way any standard part was going to work.
I've used copper pipe and compression fittings (Yorkshire fittings) and it's been fine for 2 years, saying that now it's going to break isn't it!
I do have a small pipe bender so all the angles were nice, just doing a AAZ into a T for a customer so I'll be doing the same again as the supplied ones are a bit thin looking, bit crispy!
