General Information
Troubleshooting
1.6 head gasket on 1.5 engine
Topic: 1.6 head gasket on 1.5 engine (Read 8545 times)
April 10, 2005, 11:55:59 pm
toomanycars
April 10, 2005, 11:55:59 pm »
It it possible to use the 1.6 head gasket on the 1.5? The 1.6 has a 3mm larger bore.
Regards, Peter.
1978 Golf diesel
1984 Nissan Patrol diesel
1986 Toyota Landcruiser 73 series 3B diesel
2006 Golf TDI 2.0 16v
April 11, 2005, 12:00:36 am
coke
April 11, 2005, 12:00:36 am »
Why would you want to use a 1.6L Head Gasket on a 1.5L?
April 11, 2005, 12:19:55 am
toomanycars
In the shed!
April 11, 2005, 12:19:55 am »
Because I already have one...with the right number of holes/noches.
Regards, Peter.
1978 Golf diesel
April 11, 2005, 12:39:07 am
coke
April 11, 2005, 12:39:07 am »
I think where the 1.5 has a smaller bore, the gasket for the 1.6 would be too big and wouldn't seal properly.
April 11, 2005, 05:11:31 am
Justin
April 11, 2005, 05:11:31 am »
i think that the bore is the same on the 1.5 and 1.6, its the stroke that is different, if i remember corectly the bore for both of them is right around 3.01 inches and the stroke for the the 1.5 is right around 3.25 inches while the 1.6 is right around 3.45 inches
so if this is correct then the only difference that you would have is if the head is a mechanical or hydrallic, and i think that there is a difference that you can add a sleave onto the block or something
Go to vwdieselparts.com and look for an article about this i think that jack sells something for this
hope this helps
www.archeryprostaffmi.com
April 11, 2005, 08:28:49 am
coke
April 11, 2005, 08:28:49 am »
Yes, there is an article but I believe its for using a 1.5L Head on a 1.6L block. Its an oil reducer sleeve that reduces the return passage for oil on the 1.6 block to fit the 1.5 head.
April 11, 2005, 11:30:15 pm
toomanycars
Article
April 11, 2005, 11:30:15 pm »
Yeah, I joined the forum but couldn't find the article.
Regards, Peter.
1978 Golf diesel
April 12, 2005, 04:49:57 am
Justin
April 12, 2005, 04:49:57 am »
so that reduced oil hole should be the only difference between a 1.5 and 1.6 gasket, unless they made them all with big holes for simplicity reasons
i would say use the gasket
April 12, 2005, 09:43:17 am
fspGTD
April 12, 2005, 09:43:17 am »
The coolant passages I think are different between the 1.5 and 1.6 gaskets, with the 1.5 gaskets being generally more "open" and probably not directing coolant through the head in the same way that the 1.6 gasket would.
Another area that may be differenet is the thickness of the gaskets, but I can't check that out right now.
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
April 12, 2005, 02:32:31 pm
toomanycars
I'll go for it!
April 12, 2005, 02:32:31 pm »
Thanks, Guys.
No problems with the thickness. It's 1.6mm.
Regards, Peter.
1978 Golf diesel
General Information
Troubleshooting
