Author Topic: Bunch of parts for sale! Turbo's, IP's, heads, and others!  (Read 14195 times)
February 29, 2008, 09:07:53 am
« on: February 29, 2008, 09:07:53 am »
Advertising for a friend.  he has collected quite a little cache of parts over the years...
1.6TD heads - some used and should be okay to use as-is and another one ready as a good core for rebuild not sure of the price... i think he has non turbo head(s) too.  i think one solid lifter 1.6TD head as well. $175 to $200 depending on condition
1.6TD intakes & manifolds... not sure how many there are but i saw at least 2 of each. maybe $40 for intakes and manifolds?
1.6TD injection pumps.  there is quite a few... some are okay and some leak but they could use new seals. $175
1.6 N/A pump that leaks.. 75$?
1.9TD pumps both with the adjustment on the pulley.  sold as cores.. one *might* work as is, but no guarantee's.  200$ each?
Turbo's!  A few 1.6 K24's and i think some T3's?  he also has a turbo from an '82 audi 5 cyl diesel with about 80'000km on it.  very good turbo. around $150 for turbo's depending on condition.
instrument clusters - gas & diesel with tachs... make an offer? one diesel cluster has the arm broken from the tach... will sell for less.
***specify whether you're looking for a core or something good.
***also if you're looking for little odds and ends, he probably has them!  for example the coolant flange at the front of the head.  he has a few of the aluminum ones for those who do not like the plastic kind.  he also has a bunch of bracketry...
also has an '87 nissan sentra diesel engine.  good running with around 200'000km's.  complete with harness & should have everything for a swap. couple hundred bucks for it. (can't sell it  :()
most of this stuff is OBO as i'm not too sure the value but will use what others are selling for as a basis for price.
maybe i'll go to his place with my digi camera one of these days to take some pics.
Reply #1February 29, 2008, 09:44:56 am
boostin
  • 17
« Reply #1 on: February 29, 2008, 09:44:56 am »
looking for 1.6TD manifolds. is the $40 for each or a pair  (cdn/us), and what would the freight be for one of each, intake and exhaust manifold, to US 72315.
thanks,  Ken
89 A2 Jetta restored to mostly original/stock
01 A4 Jetta 133000 w/lots of mod's
84 D50 Mighty Max P/U rice smoker
79 HOT Trans AM, Bandit look-a-like
73 F250  428 CJ  (update.. CJ has left the building)
there are more...
Reply #2February 29, 2008, 09:54:01 am
« Reply #2 on: February 29, 2008, 09:54:01 am »
Quote from: "boostin"
thanks,  Ken
i think the going rate for them separately is $40 but maybe $80 for both shipped?  i'll get some pics for you too.
Reply #3February 29, 2008, 10:01:45 am
boostin
  • 17
« Reply #3 on: February 29, 2008, 10:01:45 am »
pics would be great..
let me know... I have paypal....
BUMP:  I will take a set when you are ready.....Thanks
Ken
there are more...
Reply #4February 29, 2008, 12:42:03 pm
fastvicar
  • 154
« Reply #4 on: February 29, 2008, 12:42:03 pm »
I would take TD intake & manifold set if available as well.  Can he do a combo price w/ turbo?  (My brother is itching to turbo his Rabbit)
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #5February 29, 2008, 02:08:24 pm
quietmission
  • 96
« Reply #5 on: February 29, 2008, 02:08:24 pm »
I would take a t3 exhaust manifold if you have any.
"Let it keep on ticking"
Reply #6February 29, 2008, 03:24:59 pm
« Reply #6 on: February 29, 2008, 03:24:59 pm »
Quote from: "fastvicar"
possibly even with the turbo head to match... i'll ask!
Reply #7February 29, 2008, 03:26:38 pm
« Reply #7 on: February 29, 2008, 03:26:38 pm »
Quote from: "quietmission"
now if i'm not mistaken, K24 manifolds & T3 manifolds are the same? trapezoidal flange?  if they aren't then i'll have to check...
Reply #8February 29, 2008, 04:06:16 pm
quietmission
  • 96
« Reply #8 on: February 29, 2008, 04:06:16 pm »
I don't know much about that. I have the turbo but no manifold and oil line.
Reply #9February 29, 2008, 04:28:50 pm
rallydiesel
  • 1880
« Reply #9 on: February 29, 2008, 04:28:50 pm »
Is that the coolant flange with the two sensors on it? If so I would be interested. Does he have a Mk2 alternator?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10February 29, 2008, 04:35:03 pm
« Reply #10 on: February 29, 2008, 04:35:03 pm »
i can probably get the oil line for the turbo...  just need to look through the piles
Reply #11February 29, 2008, 04:35:45 pm
« Reply #11 on: February 29, 2008, 04:35:45 pm »
Quote from: "rallydiesel"
he has some flanges for gassers and some for diesels.  i'll get some pics!  not sure about the mk2 alt.  i'll ask!
Reply #12March 01, 2008, 01:59:42 pm
« Reply #12 on: March 01, 2008, 01:59:42 pm »
bump he might have everything needed to convert from a/c to non a/c... i'll ask him that too.
Reply #13March 01, 2008, 03:45:05 pm
tSoG-84bit
  • 188
« Reply #13 on: March 01, 2008, 03:45:05 pm »
I'm looking for a mk2 Non AC setup; alt, brackets and tensioner. Also, a 1.6 td pump core. Actually, ask him what he would want for all of it as well.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #14March 01, 2008, 04:56:02 pm
« Reply #14 on: March 01, 2008, 04:56:02 pm »
Quote from: "tSoG-84bit"
I think $150 for a core pump sounds good? pump will be leaking but should otherwise work.
I'm going to see him on Monday so I'll gather a list of what to look for.  On the phone he said he has about 4 turbo exhaust mani's and 4 turbo intake mani's.  pics to come!
