Author Topic: Bunch of parts for sale! Turbo's, IP's, heads, and others!  (Read 14115 times)
Reply #30April 20, 2008, 05:51:48 pm
hamradio
  • 282
« Reply #30 on: April 20, 2008, 05:51:48 pm »
Pics of the sentra diesel engine?  I've got a wild idea.
Reply #31April 29, 2008, 09:42:23 am
Torchd
  • 372
« Reply #31 on: April 29, 2008, 09:42:23 am »
What clusters do u have??  if you can come up with a list? thanx!
Reply #32July 06, 2008, 10:34:59 pm
VW_Commuter
  • 355
« Reply #32 on: July 06, 2008, 10:34:59 pm »
looking for a set of 8 mechanical lifters and a diesel CE2 cluster with tach.  Thanks.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #33July 13, 2008, 06:20:59 pm
dieselherb
1.6 td exh manifold
« Reply #33 on: July 13, 2008, 06:20:59 pm »
Do you have a 1.6TD exh. manifold left?
Reply #34July 17, 2008, 02:04:38 pm
angelisapayne
Cylinder Head
« Reply #34 on: July 17, 2008, 02:04:38 pm »
Do you have a cylinder head for a 1984 1.6l diesel rabbit?
Reply #35July 23, 2008, 04:42:09 am
stewardc
« Reply #35 on: July 23, 2008, 04:42:09 am »
Would you have a set of 1.9 (AAZ) injector cores?
Reply #36August 07, 2008, 06:55:58 am
zozep
  • 176
« Reply #36 on: August 07, 2008, 06:55:58 am »
How much for the best K24 you have?
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #37August 18, 2008, 08:52:53 pm
akcummins
« Reply #37 on: August 18, 2008, 08:52:53 pm »
Would you happen to have an intermediate shaft pulley or an outer lower timing belt cover.
Reply #38October 06, 2008, 08:42:17 am
stuart
  • 13
« Reply #38 on: October 06, 2008, 08:42:17 am »
looking for a tach, still have one for sale?
Reply #39October 20, 2008, 04:25:18 pm
garagebandboy
  • 15
« Reply #39 on: October 20, 2008, 04:25:18 pm »
i need a core td 1.6 pump just for the lda. $75?
Dave
Reply #40October 21, 2008, 05:32:37 am
stewardc
Re: Bunch of parts for sale! Turbo's, IP's, heads, and other
« Reply #40 on: October 21, 2008, 05:32:37 am »
Quote from: "jtanguay"
a turbo from an '82 audi 5 cyl diesel with about 80'000km on it.  very good turbo. around $150 for turbo's depending on condition.
What make is this? Also, does it have the same mounts as the T3?
