Author Topic: lowering the compression  (Read 2356 times)
February 28, 2008, 07:37:15 am
Benjamin
  • 485
« on: February 28, 2008, 07:37:15 am »
Is it possible to lower the compression when you take out the glow plugs and screw in just a bolt?
how much should the CR lower?
not for daily use, it will start with 'start pilot'
Greetz, Benjamin
Must make +250hp
Reply #1February 28, 2008, 08:07:01 am
« Reply #1 on: February 28, 2008, 08:07:01 am »
I'm sure it would lower a little, but not very much. I think the best way to lower it would be take some off the pistons where they have already been machined.
Reply #2February 28, 2008, 10:38:08 am
Benjamin
  • 485
« Reply #2 on: February 28, 2008, 10:38:08 am »
how can you calculate the change in CR when you know how much cc diffrence the bolt instead of the glowplug is.
Greetz, Benjamin
Must make +250hp
Reply #3February 28, 2008, 10:56:17 am
« Reply #3 on: February 28, 2008, 10:56:17 am »
Reply #4February 28, 2008, 04:17:16 pm
andy2
« Reply #4 on: February 28, 2008, 04:17:16 pm »
I've got specially machined bolts to replace my glowplugs to help with lowering compression.I'm guessing that my Cr is 18.5-17.5:1 now with the masive prechambers that are in my head.
