Author Topic: CC's above piston and compression ratio / pre cup cc volume  (Read 9616 times)
February 10, 2008, 12:27:59 pm
subsonic
  • 1836
« on: February 10, 2008, 12:27:59 pm »
Found this in a old post by racer-x:
Here's a "chart" of volume above the piston vs. compression ratio.  Also included is a quote from Dave with pre cup volumes:
Quote from: 935racer
I am working on compiling as much info as possible on the vw idi pre cup inserts. Today I bought a brand new 1.9 pre cup, and I pulled a 1.6td precup and a 1.6 na pre cup and measured the volume.
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
cc above piston | compression ratio
18 | 23:1
18.5 | 22.4054054054054:1
19 | 21.8421052631579:1
19.5 | 21.3076923076923:1
20 | 20.8:1
20.5 | 20.3170731707317:1
21 | 19.8571428571429:1
21.5 | 19.4186046511628:1
22 | 19:1
22.5 | 18.6:1
23 | 18.2173913043478:1
23.5 | 17.8510638297872:1
24 | 17.5:1
24.5 | 17.1632653061224:1
25 | 16.84:1
25.5 | 16.5294117647059:1
26 | 16.2307692307692:1
26.5 | 15.9433962264151:1
27 | 15.6666666666667:1
27.5 | 15.4:1
28 | 15.1428571428571:1
28.5 | 14.8947368421053:1
29 | 14.6551724137931:1
29.5 | 14.4237288135593:1
30 | 14.2:1
Reply #1February 11, 2008, 05:13:50 am
saurkraut
  • 904
Re: CC's above piston and compression ratio / pre cup cc vol
« Reply #1 on: February 11, 2008, 05:13:50 am »
Quote from: subsonic
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
quote]
Are those the volumes of just the swirl chamber covers, or the whole swirl chamber, including injectors, heat shields, and glow plugs?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2February 11, 2008, 06:25:47 am
MJF
  • 581
« Reply #2 on: February 11, 2008, 06:25:47 am »
Quote from: saurkraut
Quote from: "subsonic"
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
quote]
Just covers, I´ve measured 10-12cc from different heads.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3February 11, 2008, 07:14:23 am
« Reply #3 on: February 11, 2008, 07:14:23 am »
And I assume the CR is for a 1.6 as a 1.9 would have a different CR for the same volume.
Reply #4February 11, 2008, 07:51:53 am
saurkraut
  • 904
« Reply #4 on: February 11, 2008, 07:51:53 am »
Thats interesting. I've computed the following from engine data tables:
1.5 Swirl chamber volume 11.457 cc
1.6 Swirl chamber volume 12.794 cc
1.9 Swirl chamber volume 16.376 cc
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5February 11, 2008, 10:25:49 am
MJF
  • 581
« Reply #5 on: February 11, 2008, 10:25:49 am »
Quote from: "saurkraut"
These include chamber in piston top and piston to head clearance too.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
