Author Topic: Turbo flange gasket  (Read 7668 times)
February 23, 2008, 12:23:53 pm
boxer246
  • 109
Turbo flange gasket
« on: February 23, 2008, 12:23:53 pm »
WHat kind of gasket is supposed to be between the exhaust manifold and turbo?  THis is for a 1.6TD with Garrett T3.  I never saw one, and havent seen any for sale anywhere.
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #1February 23, 2008, 03:47:05 pm
dillenger1
  • 777
Turbo flange gasket
« Reply #1 on: February 23, 2008, 03:47:05 pm »
Ive heard you dont need one.I may be wrong
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2February 23, 2008, 06:16:24 pm
subsonic
  • 1836
Turbo flange gasket
« Reply #2 on: February 23, 2008, 06:16:24 pm »
Perfectly flat on both surfaces, you should be good to go.
Reply #3February 23, 2008, 09:32:42 pm
Turbo flange gasket
« Reply #3 on: February 23, 2008, 09:32:42 pm »
I have one of the gaskets, still in the packaging if you are interested.
Reply #4February 24, 2008, 01:16:26 am
Baselyne
Turbo flange gasket
« Reply #4 on: February 24, 2008, 01:16:26 am »
There wasnt one on mine when I removed it....manifold to turbo
Reply #5February 24, 2008, 06:43:34 am
hillfolk'r
  • 1532
Turbo flange gasket
« Reply #5 on: February 24, 2008, 06:43:34 am »
Quote from: "libbybapa"
Use a light smear of Permatex Ultra Copper and it will seal fine even if it's slightly out of flat.
Andrew
yup,stuff is awesome!! i swear by it,not at it :lol:
also if ya wanted,ive done this on my latest turbo setup
hit your local metal supplier and get a little scrap sheet of .060(approx)
copper
i gave the guy like 3 dollars for it
then i traced and cut with a dremel
i made 2 gaskets,1 between the manifold and adapter
and 1 between the adapter+turbo
if stupid imageshack wasnt down,id post a pic :cry:  :cry:  :cry:  :cry:  :cry:
Throttle cables ftw
Reply #6March 11, 2008, 10:09:47 am
Baselyne
Turbo flange gasket
« Reply #6 on: March 11, 2008, 10:09:47 am »
that's a good idea... Where do you buy these oem ones? Dealer?
Reply #7March 11, 2008, 10:52:41 am
Benjamin
  • 485
Turbo flange gasket
« Reply #7 on: March 11, 2008, 10:52:41 am »
i dont use gaskets becouse most of the cars i see its original without.
i ever go to an Audi garage wich do had this original equiped, after i asked it they searched for it, and told me they dont use it anymore becouse without is also good enough
Greetz, Benjamin
Must make +250hp
Reply #8March 11, 2008, 10:54:40 am
Baselyne
Turbo flange gasket
« Reply #8 on: March 11, 2008, 10:54:40 am »
nice to know...How would one ever know if all the ones they took off didnt have them...
Reply #9March 11, 2008, 12:56:24 pm
Quantum TD
  • 1195
Turbo flange gasket
« Reply #9 on: March 11, 2008, 12:56:24 pm »
Quote from: "Baselyne"
I dont' see any gasket listed in the ETKA for either the MK 1 or 2. I don't think VW ever had one.
You might try prothe. In a similar manner, no gasket was specified for the MK 3 TDI, but I see he carries a gasket that works.
Reply #10March 11, 2008, 01:09:12 pm
Turbo flange gasket
« Reply #10 on: March 11, 2008, 01:09:12 pm »
i'm getting an exhaust leak from somewhere... i'm not too eager to find out where, but it feels like i have a laggy turbo :(  i would recommend using a gasket unless you machine both surfaces real nice and flat... but even then stuff can happen.  if you lose that precious exhaust gas to a leak, you will lose performance, and the inside of your car will be smelly  :lol:
Reply #11March 12, 2008, 01:26:14 pm
boxer246
  • 109
leak
« Reply #11 on: March 12, 2008, 01:26:14 pm »
I noticed, right before I put my turbo on the manifold, that the manifold flange was not flat....at all.  I put a machinists straight edge on it and (without using feeler gauges) I would guess it was about 10 thousandths warped.  I filed it till it was perfectly flat again so It would make a good seal with the turbo.  Then I used a very small amount of ultra copper, like someone mentioned and the turbo sealed up perfect.
So if you have a leak, I would start to check here.  Ten thousandths is enough for a leak.
Ash
Reply #12March 12, 2008, 06:33:09 pm
Turbo flange gasket
« Reply #12 on: March 12, 2008, 06:33:09 pm »
I have a seen a couple on TDs, probably about 50/50
Reply #13March 13, 2008, 08:09:20 am
Baselyne
Turbo flange gasket
« Reply #13 on: March 13, 2008, 08:09:20 am »
sounds like without it were asking for a leak
It's wild that 50% of them had and others didnt
Reply #14March 17, 2008, 03:36:52 pm
Baselyne
Turbo flange gasket
« Reply #14 on: March 17, 2008, 03:36:52 pm »
Altrom.......PN# 893253115 center pipe gasket 14th item from the top
click here
