General Information
Upgrades (non engine related )
Rim size
Topic: Rim size (Read 3885 times)
February 07, 2008, 10:28:06 am
Helliouse
Rim size
February 07, 2008, 10:28:06 am »
What is the biggest rim size that people have fit under a 90 jetta, with out rubbing, cutting etc.?
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
February 07, 2008, 02:39:10 pm
Op-Ivy
Rim size
February 07, 2008, 02:39:10 pm »
16's should work fine which is what I'll be running come spring. 17's may have some rubbing issues depending on the weight of the car, if you have it lowered and what shocks/springs you are using. Also, it will depend on the width and offset of the wheel as well.
February 08, 2008, 10:58:56 am
Helliouse
Rim size
February 08, 2008, 10:58:56 am »
Thanks!
February 10, 2008, 09:10:10 am
Patrick
Rim size
February 10, 2008, 09:10:10 am »
Depends on offset and tire size. I've got a set of 15" BBS rims, standard offset. Can't run a tire taller than 195/60R 15. Might get away with 205/50R, not sure.
General Information
Rim size
