Author Topic: Rim size  (Read 3883 times)
February 07, 2008, 10:28:06 am
Helliouse
  • 164
Rim size
« on: February 07, 2008, 10:28:06 am »
What is the biggest rim size that people have fit under a 90 jetta, with out rubbing, cutting etc.?
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #1February 07, 2008, 02:39:10 pm
Op-Ivy
  • 513
Rim size
« Reply #1 on: February 07, 2008, 02:39:10 pm »
16's should work fine which is what I'll be running come spring. 17's may have some rubbing issues depending on the weight of the car, if you have it lowered and what shocks/springs you are using. Also, it will depend on the width and offset of the wheel as well.
Reply #2February 08, 2008, 10:58:56 am
Helliouse
  • 164
Rim size
« Reply #2 on: February 08, 2008, 10:58:56 am »
Thanks!
Reply #3February 10, 2008, 09:10:10 am
Patrick
  • 1034
Rim size
« Reply #3 on: February 10, 2008, 09:10:10 am »
Depends on offset and tire size. I've got a set of 15" BBS rims, standard offset. Can't run a tire taller than 195/60R 15. Might get away with 205/50R, not sure.
