Author Topic: help with manualy disengaging the locking gas cap?  (Read 5147 times)
January 27, 2008, 06:26:05 pm
dieseldubber
  • 81
« on: January 27, 2008, 06:26:05 pm »
Hi there. due to my water woes with the electrical system and the power locks not functioning, I am unable to open the gas tank flap to refuel. Is there a way to unlock it manualy from inside the trunk? I would just figure it out myself but the car is not with me, its with my girlfriend in Victoria. Thanks, I know this should be an easy one.
'85 1.6TD JettaGL
Reply #1January 27, 2008, 07:24:55 pm
MaxHedrm
  • 114
    • blog
« Reply #1 on: January 27, 2008, 07:24:55 pm »
There should be a tag you can pull on. On my MK3 GTI I think it was sort of velcroed to the wall of the cargo area.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #2January 27, 2008, 08:13:49 pm
dieseldubber
  • 81
« Reply #2 on: January 27, 2008, 08:13:49 pm »
yep I hope there is but does anyone know for sure if there's something on the MKII?
'85 1.6TD JettaGL
Reply #3January 28, 2008, 05:59:17 pm
dieseldubber
  • 81
« Reply #3 on: January 28, 2008, 05:59:17 pm »
bump...can anyone help here please?
'85 1.6TD JettaGL
Reply #4January 28, 2008, 08:01:12 pm
bigblockchev
  • 271
« Reply #4 on: January 28, 2008, 08:01:12 pm »
I have both a mk3 and a mk2 the mk3 has a release in the trunk but the mk2 does not lock the flap since the locks are all manual not electric. check your owners manual? Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #5January 29, 2008, 01:25:30 pm
MikkiJayne
  • 235
« Reply #5 on: January 29, 2008, 01:25:30 pm »
The mkII uses a vacuum actuator to lock the filler flap (plus everything else). There is no manual release, but...
If you look behind the carpet in the trunk above the wheel well you can see the actuator for the filler flap. You may be able to operate it manually if you can reach the rod on the end of it. It not it's held in with two pozi screws - if you remove those you can move the actuator just enough to release the filler flap, although you may need someone else to open the flap while you move the actuator.
Good luck  :)
Mikki x
Reply #6January 29, 2008, 05:56:13 pm
dieseldubber
  • 81
« Reply #6 on: January 29, 2008, 05:56:13 pm »
thank you
'85 1.6TD JettaGL
Reply #7January 31, 2008, 01:54:19 pm
mtnbob
  • 738
« Reply #7 on: January 31, 2008, 01:54:19 pm »
you know many of them are manual open. mine had a small edge that you pull on to open. it wasn't readily apparent to me. I was looking around for the fuel door release for an hour before i figured it out :roll:
86 VW Golf 1.6 N/A 4-door (soon to be turboed!!!)
http://farm4.static.flickr.com/3248/2598033828_d3d19f9842.jpg?v=0
96 Subaru Outback Wagon
Reply #8February 01, 2008, 07:46:03 am
BlackTieTD
  • 1512
« Reply #8 on: February 01, 2008, 07:46:03 am »
go at it from the back as suggested and try to manually release it either by way of some sort of manual mechanism you might find back there, or by messing with the vacuum lines. i don't know how that vacuum crap works and i don't want to know but if you either eliminate the vacuum (pull off the hose) or add a vacuum (use a hand pump or another running VW that makes vacuum) it should operate as intended.
Reply #9February 01, 2008, 08:12:30 am
MikkiJayne
  • 235
« Reply #9 on: February 01, 2008, 08:12:30 am »
If you're still stuck on this post up and I'll get some pics of what you need to do  :)
Reply #10February 02, 2008, 09:20:17 pm
dieseldubber
  • 81
« Reply #10 on: February 02, 2008, 09:20:17 pm »
ok thanks everyone. I am happy that people on this site are so helpful and unpretentious. It is really really nice. My girlfriend took it to the dealership in Vic. and they opened it up for $37.00. If I was there I would have done it but hey, she's happy and driving it around now. Damn she looks good in that thing too! Now I'm look forward to tackling the real problem of the short somewhere that caused this in the first place. Actually not really.
'85 1.6TD JettaGL
