Author Topic: the generator!  (Read 24336 times)
Reply #30April 06, 2008, 10:45:09 pm
  • 2932
the generator!
« Reply #30 on: April 06, 2008, 10:45:09 pm »
Hey is that waterport gasket on wrong?
 Hard to tell but it looks a little like this:
 Maybe you used one for the front waterneck
Reply #31April 07, 2008, 03:07:32 am
dillenger1
  • 777
the generator!
« Reply #31 on: April 07, 2008, 03:07:32 am »
Yep it HAS D-SHAPED PORTS theres just a little gasket in the airstream,and the sealing surface is a little thin around the top,but there is a seal.My water port casting is a little funny on one side so my gasket shows on the outside,The front is an o-ringed seal.I figure the d-port wouldnt be a problem since the air is pressurrized anyway
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #32May 23, 2008, 05:26:01 pm
dillenger1
  • 777
the generator!
« Reply #32 on: May 23, 2008, 05:26:01 pm »
well ive been dormant for awhile,but things are moving again.I had to wait to find a body for the motoir.I chose a 87 yota 4runner.She weighs in at 3000 lbs so its pretty much a vanagon.I wanted to do something a little more interesting.Plus were getting our bio system setup,so weve been busy.
heres what the toy flywheel will look like,and an adapter for the block.
this is not my design.It belongs to flash319 for yotatech.heres a pic of our pad for bio setup.we really went all out on this one should be fun.
http://www.yotatech.com/f162/vw-diesel-build-up-135203/?highlight=vw+diesel+swap
heres flash319 build up ive been following.
Reply #33September 01, 2008, 01:55:06 pm
dillenger1
  • 777
the generator!
« Reply #33 on: September 01, 2008, 01:55:06 pm »
Ive finally got it running,with a little help from you guys that is. :) Ive got some troubles though.I had to turn the fuel screw in about 4 turns to even get fuel to the lines,Ive tried to back it off,but it seems theres a fine line to where it will run and where it wont get fuel at all.I didnt compare the spill ports when i had it out.I have it timed to 1.05mm,and theres a 10mm plunger from a peug.It will idle nice ,but it wont rev(poor response).It will run away when you hold the throttle at max for over 5 seconds,and wont come back down.I havent touched the gov. assembly(only used the peug inter. spring)Lda is still on peug. settings(I swapped it to a na pump)heres some pics anyway
we extracted more water through a drying process that blows air through hot oil,and seperates the water from it.
Reply #34September 01, 2008, 02:04:42 pm
dillenger1
  • 777
the generator!
« Reply #34 on: September 01, 2008, 02:04:42 pm »
I wish my thread wasnt so jacked up! :evil: Anyway im sorry for all those that have dial up.Dont let this hinder you from giving me advice. :) Anyways,does this sound like timing issue?
Reply #35September 01, 2008, 03:53:22 pm
gigaz2
  • 626
the generator!
« Reply #35 on: September 01, 2008, 03:53:22 pm »
my opinion is that your governor should resign :D
try with different settings of the throttle assembly, mine is on minimum, it idles without touching the idle screw. (I got tired of huge black clouds on the other settings)
it doesn't sound like timing issues, but you can forget about timing with the dial indicator, I guess it only works with stock parts, you have a sharper injection start now.
Reply #36September 01, 2008, 03:56:45 pm
blkboostedtruck
  • 1535
the generator!
« Reply #36 on: September 01, 2008, 03:56:45 pm »
hey Ben,
those pics. are so small except for 1! anyway you can post them bigger?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #37September 02, 2008, 08:42:44 am
the generator!
« Reply #37 on: September 02, 2008, 08:42:44 am »
Does the peug pump head have a recessed hole where the 2 large springs rest?
Does the head you removed?
I'm not talking about the 2 little pencil side springs the 2 large ones that sit on a shaft on either side of the plunger.
Reply #38September 02, 2008, 03:39:25 pm
dillenger1
  • 777
the generator!
« Reply #38 on: September 02, 2008, 03:39:25 pm »
I dont think so.The springs where the same same shims and everything.Wouldnt the recess give them less preload if the springs are the same?the head i removed does not,its a vw 9mm head.It idles fine,sounds great.well you hit the accelerator it will only go to say maybe 1200rpm(no tach)When you hold down the accelerator for a while it will start to climb and run away.Are you guys thinking it almost has to be springs?is there anything else that will give this? ive not messed with the lda at all.Remember pump body is from an na.
Reply #39September 02, 2008, 04:32:26 pm
dillenger1
  • 777
the generator!
« Reply #39 on: September 02, 2008, 04:32:26 pm »
Ok ,i read some other posts and came up with the gov. assembly not being properly aligned with the collar plate.I forgot to scribe lines on the nut and lever for reassembly :oops: I know!Does anyone think this is culprit?If i use a picture of another pumps lever shaft/nut relation will this get me close?If the parts are identical then the adjustment should be right?
Reply #40September 03, 2008, 07:43:51 am
the generator!
« Reply #40 on: September 03, 2008, 07:43:51 am »
If the main springs on the pump head are wrong it wont do much of anything correctly other than idle.
On the other hand if you have the throttle shaft keyed incorrectly that will cause the problem you are experiencing.
Reply #41September 04, 2008, 03:31:25 am
dillenger1
  • 777
the generator!
« Reply #41 on: September 04, 2008, 03:31:25 am »
I removed the accelerator lever,and it acted normally.first it fire,and i still had the full load way in!It fired and went for the moon. :D I backed that off to stock position,and removed the lever.I then gave it various settings of preload to determine my idle point.yah!So its behaving quite normally now.I still would like to know if the 10mm plunger is advancing the injection.I kknow it will be sharper,
Reply #42September 05, 2008, 03:57:59 pm
dillenger1
  • 777
the generator!
« Reply #42 on: September 05, 2008, 03:57:59 pm »
Ok ive still got some trouble.Ive got white smoke at idle with 1.05mm with 160bar "gtd"injectors.I think the injectors are slowing me down.I think i still need more advance! :shock:
Ohh yahhh!check this out!! :D what could it be?hmmmmmm...
Reply #43September 17, 2008, 08:15:00 am
dillenger1
  • 777
the generator!
« Reply #43 on: September 17, 2008, 08:15:00 am »
ohhhhhh Yah!!! :D  :D  :lol:  :lol:
2 1/2" down pipe home made with header wrap
Reply #44September 17, 2008, 09:05:48 am
gigaz2
  • 626
the generator!
« Reply #44 on: September 17, 2008, 09:05:48 am »
beatiful DP!
