Author Topic: WTB: Vacuum Canister for 1985 VW Jetta TD  (Read 3963 times)
January 24, 2008, 12:59:18 pm
jonz
  • 28
« on: January 24, 2008, 12:59:18 pm »
I need one of these(with the check valve if possible) so that i can get the heater working properly in my car.
I am also looking for a grille for the same year Jetta.
Thanks!
jz
1985 VW Jetta TD
Loveland, Co.
Reply #1January 24, 2008, 02:22:12 pm
Baselyne
« Reply #1 on: January 24, 2008, 02:22:12 pm »
do you have a picture of the vacume pump your looking for?
I might just have one, show in the pic the heater check valve, yeh
Reply #2January 25, 2008, 05:56:45 am
jonz
  • 28
« Reply #2 on: January 25, 2008, 05:56:45 am »
Unfortunatley, I don't have a pic... The mechanic that is working on my car said that the orginal was removed...
From what i understand it is simply a vacuum resivoir used to hold vacuum pressure so that the bellows in the heating system work more quickly...
If anyone has a better knowledge of how the vacuum system works in an 85 Jetta and wouldn't mind chiming in i would appreciate it.
jz
1985 VW Jetta TD
Loveland, Co.
Reply #3January 25, 2008, 06:49:40 am
Baselyne
vac
« Reply #3 on: January 25, 2008, 06:49:40 am »
I just need a picture because I have two different ones here both are brand new.....
thanks for your time
