Author Topic: FS: "NEW" AHU block, crank, etc.  (Read 4375 times)
January 21, 2008, 08:47:24 pm
vwmike
  • 1158
« on: January 21, 2008, 08:47:24 pm »
I bought this block with crank, and intermediate shaft, but only 3 rods and pistons. It is technically a new block but has been sitting under my bench for a while so it could use some cleaning and whatnot. When it was shipped to me before they put a small flat spot on the front of it and there is a scratch on the deck. It could all be fixed pretty easily. The important part here is that the bores are good which means a cheap and easy rebuild. Since I only have 3 of the pistons and rods I had plans on buying a set of used ALH pistons and rods. Polish up the crank and throw it together with new rings and bearings. Obviously none of that ever happened though and I ended up skipping over the AHU project and heading for the PD150. So, as a result I don't really have a use for this stuff and it isn't doing anyone any good under my bench.
Here are some pictures of what I have
Things have gotten a little crusty as you can see but I don't think it should really present a huge problem. I'm not sure what to ask so go ahead and send me a message if you're interested and we'll see if we can work something out. FYI, this is the block that bolts into a Rabbit.
Reply #1January 21, 2008, 08:55:48 pm
blkboostedtruck
  • 1535
« Reply #1 on: January 21, 2008, 08:55:48 pm »
Mike,
have you gotten any messages from me
please P.M. me!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2January 21, 2008, 09:06:29 pm
vwmike
  • 1158
« Reply #2 on: January 21, 2008, 09:06:29 pm »
PM sent.
Reply #3January 25, 2008, 01:17:51 pm
vwmike
  • 1158
« Reply #3 on: January 25, 2008, 01:17:51 pm »
SOLD!
