Author Topic: junkyard find  (Read 3671 times)
January 14, 2008, 07:22:45 pm
silvertdi
  • 125
junkyard find
« on: January 14, 2008, 07:22:45 pm »
I found a cool VDO gauge at the junkyard yesterday.  Units are kp/cm2.  Definately for pressure.  Is that the standard unit for Euro golfs?  I got it out of a Porsche 924.
Reply #1January 14, 2008, 10:27:34 pm
Quantum TD
  • 1195
junkyard find
« Reply #1 on: January 14, 2008, 10:27:34 pm »
I think all the VW ones were graded in BAR (BAR is basically KP/CM2). I imagine the Golf (if it had one, it only came on the GTD), was similar to the Cabriolet one, graded at 1-5 bar.
That's a cool gauge, I actually have one on ebay right now. You will need the oil pressure sender (rated at 1-10 bar) in order to use that gauge. It's located on the back of the head, between the engine and the firewall. It's a really pain to get out. Be sure to cut the wires before you try to remove the sender.
Reply #2January 15, 2008, 03:50:41 am
silvertdi
  • 125
junkyard find
« Reply #2 on: January 15, 2008, 03:50:41 am »
Thanks Quantum.  It's in very good condition so I think I'll use it when I get around to installing gauges.  It's not a unit you usually see, so it's unique.
