Hard starting on 93 td...why??
Topic: Hard starting on 93 td...why?? (Read 7272 times)
March 24, 2005, 10:33:18 pm
Topherdiesel
March 24, 2005, 10:33:18 pm »
I have noticed just the last few weeks that shes starting hard, maybe veen harder than in the winter.
I know my timing is off, could this be why?
She starts right up, but chugs and chugs and smokes for a while, total incomplete combustion.
What could cause, I KNOW i am way overdue for a fuel filter?
After shes runnign she runs very well, very strong!
March 25, 2005, 07:20:00 am
QuickTD
March 25, 2005, 07:20:00 am »
Sounds like a bad glow plug. New ones go bad just as often as old ones so check them all.
March 25, 2005, 08:07:37 am
Topherdiesel
March 25, 2005, 08:07:37 am »
What a pain in the ass
I KNEW you were gonna say that!!!
March 25, 2005, 08:51:20 am
Hammy
March 25, 2005, 08:51:20 am »
I had the same problem you have described, and it turned out to be glow plugs. Almost the same time of year. It just got really hard to start, wasn't that cold out. Changed the glow plugs, and it was perfect again. All winter it started with no problems, they just fail all of a sudden.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
March 25, 2005, 09:18:36 am
Topherdiesel
March 25, 2005, 09:18:36 am »
Son of a ***ing things, I JUST changed them at xmas time!
:evil:
March 25, 2005, 09:47:02 am
QuickTD
March 25, 2005, 09:47:02 am »
Are you sure you used the correct ones? Some jobbers and dealers still have the old non-self regulating fast glow plugs. These will burn out quite quickly in a 1.9 because they stay on for 3 minutes. Make sure the boxes say "duraterm" on them and the glow plugs should have a thin tapered tip. The old fast glow plugs have a blunt rounded tip.
March 25, 2005, 01:15:14 pm
Topherdiesel
March 25, 2005, 01:15:14 pm »
Yep, then the woman at frisco gave me the wrong ones.
They were the only ones she had, where do I go get the right ones?
March 25, 2005, 01:15:45 pm
Topherdiesel
March 25, 2005, 01:15:45 pm »
Thats why my car started like ASS all winter...
what a day
March 25, 2005, 04:00:10 pm
gropar
User+
March 25, 2005, 04:00:10 pm »
Mine had the same symptoms.
Ended up to be bad injectors. They would skirt rather than spray, wich gave me about 3 minutes of rough idle and mises when temperature was below 5°C.
ID
I
minimalist exhaust system; soon big FMIC and 15 psi boost.
March 25, 2005, 04:51:53 pm
Topherdiesel
March 25, 2005, 04:51:53 pm »
whats the part # for the duraterm glow plugs?
March 25, 2005, 05:07:35 pm
Topherdiesel
March 25, 2005, 05:07:35 pm »
the ones i have here say 0 250 032 015
vw oem made in france
Reply #11
March 25, 2005, 06:31:32 pm
QuickTD
Reply #11 on:
March 25, 2005, 06:31:32 pm »
The bosch part number is 0 250 201 032. This may be the same part number as older fast glow plugs but the plug in the box should be a duraterm. There could be some old stock around though. Beru also makes a self regulating glow plug that is suitable for use in 1.9TD and 1.6 fast glow systems. The part number is GN857.
Reply #12
March 25, 2005, 07:58:16 pm
Topherdiesel
Reply #12 on:
March 25, 2005, 07:58:16 pm »
sorry
the ones I have say
0 250 201 032 015
so, are they the same damn plug?
they dont say duraterm anywhere?
it also has these #'s on the box
N 102 130 02
Reply #13
March 25, 2005, 08:00:08 pm
Topherdiesel
Reply #13 on:
March 25, 2005, 08:00:08 pm »
Sorry, and where do I get the CORRECT plugs, cuz apparently frisco is NOT it!
Reply #14
March 25, 2005, 08:36:37 pm
Reply #14 on:
March 25, 2005, 08:36:37 pm »
well i've been living with bad starting for a while now, will this hurt my engine in any way? (If not I'll just change them later when its warm out, nice smoke coming from the back of my car when I start lol)
my guess is that this won't hurt my engine, but if anyone has any other opinion I'd like to hear it (maybe the extreme bucking??? mix that in with my bad motor mount too...)
