Author Topic: Hard starting on 93 td...why??  (Read 7257 times)
Reply #15March 26, 2005, 07:00:25 am
QuickTD
  • 1156
« Reply #15 on: March 26, 2005, 07:00:25 am »
sorry
the ones I have say
0 250 201 032 015
so, are they the same damn plug?
they dont say duraterm anywhere?
it also has these #'s on the box
N 102 130 02
There is some confusion because the duraterm plugs superceded the old fast glow plugs but the part number (Bosch or VW) was not changed. There may be still some old stock out there. The only way to tell the difference is to look at the plugs themselves. The self regulating type have a thinner tapered tip. The old fast or glow types have a constant diameter all the way to the end. Heres a link to a pic -  http://www.boschautoparts.co.uk/pcGlow2.asp?c=2&d=1
Macgyver posted a cheap source of beru glow plugs awhile ago, here's the link - http://vwdiesel.net/phpBB/viewtopic.php?t=719&highlight=
You need the GN857's for your 1.9TD. Have you tested the existing glow plugs yet?
Reply #16April 02, 2005, 11:03:49 pm
vixentd
  • 88
hard starting
« Reply #16 on: April 02, 2005, 11:03:49 pm »
It may not be your glowplugs but your timing as your crankshaft pulley may be worn.  It is critical that you remove it to check the keyway on the pulley for wear.  Mine did this, and before I checked it, destroyed the motor. It was only noticeable when cold.  Should have listened to my wife when she said it was running rought.  Thought it was glow plugs also, so left it for a few weeks.
If there is any wear, you can not just replace with a new pulley as the crank will be worn also.
Reply #17April 03, 2005, 06:18:46 am
Topherdiesel
  • 132
« Reply #17 on: April 03, 2005, 06:18:46 am »
Car runs fine after about a minute, just rough on the start, and my crank has been done witht he new pulley from the tdi!
