Author Topic: FS: 1996 vw jetta, 1.9L diesel  (Read 4917 times)
January 02, 2008, 04:27:42 pm
insdtanoodles
  • 148
« on: January 02, 2008, 04:27:42 pm »
Well its pretty much a parts car, the body is shot. I will just sorta go over the good and bad things.
Bad:
    -The body, there is rust everywhere and I think the factory undercoating is what is holding the back of the car together
    - The drivers side cv joint sounds toast but I havent actually taken a closer look
    - Brake master cylinder blew a seal in the back and my guess is the brake fluid is being dumped into the booster. there are no brakes
    - Drivers seat is broken, using the spare tire jack to keep is level
Good: lots of new things, I will break it down by km's
20,00kms
    -rebuilt injector pump by giles, with new injector nozzles also setup by giles.
    -All new shifter bushing but I think I am still missing something cause there is still some play
    - All new motor mounts, new clutch, throw out bearing, new main and con-rod bearings, new 4 pc thrust washers
    - Crank was out and the thrust surface was repaired and journals micropolished, used brand new bolts from vw when rebuilding the bottom end
     - New timing belt, tensioner, water pump, 3-way coolant pipe, power steering line - pressure side.
50,00kms
   - Rebuilt KKK-K03 turbo, pushing 10psi all day long
90,000kms
    -rebuilt cylinder head, when installed there were no cracks between the valves/pre-chambers. The car has been babied ever since, no hard acceleration till the car has gotten up to operating temp.
    - honed out the cylinder bores and re-ringed the engine, now there is next to no blow by.
    - Crank repaired to fit tdi styled sprocket
    - upgraded harmonic balancer and one way alternator clutch pulley
I am sure there is more, I dont think I ever really stoped dumping money into that thing. It was a total wreck when I got it and now the engine runs like a top. Its a shame that the body is in such bad shape.
I just did an oil change on it and comming down off the ramps is when I lost the brakes but they had been slowly leaking for awhile, I had assumed it was a wheel cylinder. On my last oil change I did approx. 12,000km with lurbo-moly 5w-40 full synthetic and the motor lost about 3/4 of a L. I dont know if it is burning oil but I do know that the valve cover gasket is leaking, the nuts to hold down the cover at worn and I cant torque it down but I do have the new nuts for it.
I also have a brand new rebuilt bosch starter and wheel cylinder that I am not using and a garage full of odds and ends, like the vacume pump for the locks, some read drums, replays, wiper motor.
I think that about covers it, the car is in no condition to be safetied and would make a great parts car or if someone is doing a diesel swap and needs a good motor. I dont know what all this would be worth since it is only worth what people are willing to pay, so if you are interested send me a pm was we can work something out.
1996 vw jetta AAZ
Reply #1January 02, 2008, 04:56:21 pm
blkboostedtruck
  • 1535
« Reply #1 on: January 02, 2008, 04:56:21 pm »
how far are you from Tyler (burn your money)?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2January 02, 2008, 05:38:08 pm
insdtanoodles
  • 148
« Reply #2 on: January 02, 2008, 05:38:08 pm »
about 250 kms
1996 vw jetta AAZ
Reply #3January 02, 2008, 09:43:03 pm
foxracer1
  • 991
« Reply #3 on: January 02, 2008, 09:43:03 pm »
Do you have any pics?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4January 02, 2008, 10:26:05 pm
« Reply #4 on: January 02, 2008, 10:26:05 pm »
If you want Duane I can get it for you 8)
Reply #5January 03, 2008, 02:47:22 am
insdtanoodles
  • 148
« Reply #5 on: January 03, 2008, 02:47:22 am »
Quote from: "foxracer1"
If my brother has his digital camera with him then I can get some pics.
1996 vw jetta AAZ
Reply #6January 03, 2008, 04:15:32 am
« Reply #6 on: January 03, 2008, 04:15:32 am »
how much do you want for the engine?  asking price?
Reply #7January 03, 2008, 02:47:06 pm
insdtanoodles
  • 148
« Reply #7 on: January 03, 2008, 02:47:06 pm »
Quote from: "jtanguay"
I dont really want to part everything out, im kinda selling the engine and it comes with a body.
1996 vw jetta AAZ
