Author Topic: upgrade a 1.6L non turbo to turbo  (Read 7709 times)
December 28, 2007, 08:20:43 pm
yeagerjf
  • 12
« on: December 28, 2007, 08:20:43 pm »
I have a jetta with the 1.6L non turbo.  What benefits would I gain by putting a turbo on the engine?
Reply #1December 29, 2007, 04:05:24 am
dillenger1
  • 777
« Reply #1 on: December 29, 2007, 04:05:24 am »
If you also turn up the fuel,theres lots of power to be had.I wouldnt think you could get a 1.6 over 130 hp without major mods!With just the turbo,not much.Then its pretty much an eco=diesel.With the correct IP turned up,and 20lbs of boost to go with it you could see substantial gains.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2December 29, 2007, 04:07:32 am
dillenger1
  • 777
« Reply #2 on: December 29, 2007, 04:07:32 am »
Oh yah watch yer EGTs.Im doing the same thing and thats what they told me.YOu want to intercool,and use the oil cooler,larger downpipe,K14 turbo(optional)
Reply #3December 29, 2007, 05:24:52 am
Diesel Fumes
« Reply #3 on: December 29, 2007, 05:24:52 am »
You would gain the benefits of forced induction. Quite simple really.  Boost levels can go insanely high if you want them to be.
In other words, your diesel will now have the potential to be fast  :twisted:
Reply #4December 31, 2007, 08:05:50 am
Baselyne
and 1.5n/a to turbo
« Reply #4 on: December 31, 2007, 08:05:50 am »
What differences would someone see if they put a k 24setup from a 1.6ltd onto 1.5ln/a engine?
Reply #5December 31, 2007, 11:03:13 am
yeagerjf
  • 12
performance
« Reply #5 on: December 31, 2007, 11:03:13 am »
This is my first diesel vehicle and I am still learning about the engine.  My biggest goal for this car is to be my daily runner to work.  Performance is my goal with this car.
It had the timing belt replaced this past summer.  New CV joints in 05.  New alternator in 06.  Vehicle has 225K on it.  What else can I do to increase performance.
Thanks, John
Reply #6December 31, 2007, 08:53:56 pm
blkboostedtruck
  • 1535
Re: and 1.5n/a to turbo
« Reply #6 on: December 31, 2007, 08:53:56 pm »
Quote from: "Baselyne"
 IMAO that could be a really high revving engine! can make some power the only problem 1.5 always seem to develope a nasty blowby problem! if that can be worked out ? it has been done before even by the vw factory i don't know how many factory 1.5TD's are out there? pretty rare! there are aftermarket turbo kits that were made in the early '80's  drake, spearco,calloway, B.A.E. just to name a few!
those old turbo kits are still floating around used for sale everyonce in a while?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #7January 02, 2008, 12:55:06 am
Baselyne
q's
« Reply #7 on: January 02, 2008, 12:55:06 am »
Thanks alot for the input, im just beginning to get most of this...
What blow by should I be looking for, Blowby on rings? injector threads or do you mean head gaskets?
Im waiting on a turbo downpipe and im on my way to a full turbo'd 1.5LD
Thanks in advance,
-Jeff
Reply #8January 02, 2008, 10:26:07 am
Re: q's
« Reply #8 on: January 02, 2008, 10:26:07 am »
Thanks in advance,
-Jeff
Duane is refering to ring blow by.
Reply #9January 02, 2008, 03:31:37 pm
Baselyne
total seal
« Reply #9 on: January 02, 2008, 03:31:37 pm »
Im told there is a company by the name of Total seal....
i guess if I was to do the Head gasket
i might as well replace the rings!
Whos selling total seal around Oshawa?
Reply #10January 02, 2008, 04:44:44 pm
blkboostedtruck
  • 1535
« Reply #10 on: January 02, 2008, 04:44:44 pm »
the person that i know that has a 1.5TD is saurkraut on the forum he would know more about it? me and 1.5's don't get along! L.O.L. thats why i kick them around in my garage like thier my redheaded stepchilds! :twisted:
when you get it going let us know how it rips around?
thanks Duane
'66 variant 1500S
Reply #11January 03, 2008, 07:17:17 am
yeagerjf
  • 12
« Reply #11 on: January 03, 2008, 07:17:17 am »
What kind of money am I looking at to get everything I need to put the turbo on the engine?
Reply #12January 03, 2008, 07:35:04 am
« Reply #12 on: January 03, 2008, 07:35:04 am »
it depends if you want to go with the TD pump and injectors or not.
I'd expect in the $400 range though depending on who and where you buy it from and the condition of the parts
