Author Topic: valve cover  (Read 2824 times)
December 28, 2007, 07:25:01 pm
shegel
  • 312
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1December 28, 2007, 08:13:29 pm
vanagonturbo
  • 639
    • Fine Tuning
valve cover
« Reply #1 on: December 28, 2007, 08:13:29 pm »
dark pictures are dark. You really need to come over the shop some day soon. I have all kinds of neat stuff. I think I threw a few of those away the other day.
Reply #2December 28, 2007, 08:18:10 pm
shegel
  • 312
valve cover
« Reply #2 on: December 28, 2007, 08:18:10 pm »
when i go back to school in a couple of days. i will stop by.
Reply #3December 29, 2007, 03:36:17 am
Ziptar
  • 565
valve cover
« Reply #3 on: December 29, 2007, 03:36:17 am »
You can use just about any 8V valve cover in a 1.6D.
If you are going to go through the trouble of getting a new one you might as well try to get an Aluminum G60 Valve Cover. No warping or bending like the stamped steel ones, so no / less leaks and, you might see a bit of noise reduction.
They are more expensive than the steel ones and are sort of in demand but, if you are patient you can get one fairly inexpensively. I have seen them for sale on the vortex and for $50-$80. I won one on ebay a couple weeks ago for $42.
Also get the valve cover gasket upgrade kit. It's a one piece rubber gasket and new shouldered studs. It's part number 026 198 025C $15 at BusDepot while you are at it, blow $5 on a Valve Cover Oil Deflector if yours is cracked or brittle (don't want any pieces in the pan after all.) 026 103 547 $4.79
I am waiting for my gasket and deflector to arrive, mean while I have been trying to decide if I should paint the G60 VC or send it out for powder coat, or use it as is. It's not all that ugly.
Cosmetics aside I think the cast aluminum valve cover plus the one piece gasket will finally rid my 1.6TD of valve cover leaks forever... Ok well a long time, hopefully 50,000 miles. If so, it's well worth the money.
Oh.... and make a tinyurl for that ebay link  :D it's knocked my whole screen out of whack and makes my brain hurt. Your link above is reduced to http://tinyurl.com/2c2r2g
Reply #4December 29, 2007, 05:41:22 am
stewardc
valve cover
« Reply #4 on: December 29, 2007, 05:41:22 am »
I agree on the cast G60 cover. Here's mine.
Reply #5December 29, 2007, 10:21:27 am
vanagonturbo
  • 639
    • Fine Tuning
valve cover
« Reply #5 on: December 29, 2007, 10:21:27 am »
I'll third that notion. I have an aluminum cover on my engine too. No leaks. Mine is a little different though as it has the oil filler on the opposite end. It works out great because my intercooler piping goes right over where the filler would be if I had a stock or g60 valve cover.
Reply #6December 29, 2007, 11:52:13 am
stewardc
valve cover
« Reply #6 on: December 29, 2007, 11:52:13 am »
Quote from: "vanagonturbo"
I think you have what they call a G40 cover.
