Author Topic: control cone  (Read 1958 times)
December 20, 2007, 05:32:19 pm
dillenger1
  • 777
control cone
« on: December 20, 2007, 05:32:19 pm »
So ive got the LDA off my pump ,and im wondering about the control cone.Well the  modification im wondering about is the teflon washer that stops the cone from dropping to far,witch stops guide pin from running out .The width of the washer(teflon washer) is about the width of unused fuel slope on my cone,so im wondering if taking it out completely would be a bad idea or should i shave it?If i take it out completely what would happen?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1December 20, 2007, 06:20:24 pm
andy2
control cone
« Reply #1 on: December 20, 2007, 06:20:24 pm »
You need to basically make the spacer half the thickness.Removing it completely will give too much travel and cause the fuel to decrease as the boost increases.
Reply #2December 20, 2007, 06:40:04 pm
control cone
« Reply #2 on: December 20, 2007, 06:40:04 pm »
Quote from: "andy2"
How do ya figure?
If its a one sided cone not like a hour glass the fuel will continue to be delivered to the top of the cone.
dillenger1,
Take a couple measurements of the washer and the amount of travel your not getting and if it's the same take that suka out.
Mine has been MIA for almost a year now.
Reply #3December 20, 2007, 06:46:32 pm
dillenger1
  • 777
control cone
« Reply #3 on: December 20, 2007, 06:46:32 pm »
Its from a peugot 505 2.3 ltr that put out 90 hp.Its got an hour glass type(machined all the way around)
