Author Topic: Motorcraft 15w40 diesel oil ok?  (Read 4334 times)
December 15, 2007, 09:38:53 am
mtnbob
  • 738
« on: December 15, 2007, 09:38:53 am »
Motorcraft 15w40 diesel oil ok? It says good to 20 degrees F and it rarely gets that low here in south carolina. Anyone ever use it. I cost $10 for 5qts
96 Subaru Outback Wagon
Reply #1December 15, 2007, 12:38:37 pm
« Reply #1 on: December 15, 2007, 12:38:37 pm »
no experience with it, but it should be fine considering you aren't putting it into a turbo motor.  i personally would always spend the extra money for synthetic though.. that stuff goes a long long way :)
Reply #2December 15, 2007, 02:02:09 pm
mtnbob
  • 738
« Reply #2 on: December 15, 2007, 02:02:09 pm »
i'm waiting a little b4 i use synthetic, just got a rebuild. not sure how long i should wait though.
Reply #3December 18, 2007, 08:25:57 pm
madmedix
  • 204
« Reply #3 on: December 18, 2007, 08:25:57 pm »
I'm sure you'll hear both sides (switch now/switch later). Just go with what makes you feel comfortable? Up here, synth is required in the winter if longevity of the engine is a concern (nothin' like "square pistons" when it's -20 outside with a cold start on dino oil in the crankcase :shock: )
Cheers,
Andy
'90 TD Jetta
Reply #4December 19, 2007, 03:11:13 am
« Reply #4 on: December 19, 2007, 03:11:13 am »
my guess is that the engine might seat faster while running thick dino in the winter.   either way i would want to use an oil pan heater for really cold days though... at least try and put 5000km and changing rpm's helps too (while driving)
