Author Topic: Injector pump longevity  (Read 5304 times)
November 27, 2007, 10:27:51 pm
Leumas
  • 9
« on: November 27, 2007, 10:27:51 pm »
Hey I was just wondering about how long one can expect an injector pump to last on one of these engines?
I've owned several diesel 1980's VW's.  Both turbo and N/A but have never had a pump problem yet.  (knock wood).
I was just wondering about other people's experiences and how long they have lasted for you?
Reply #1November 28, 2007, 04:26:46 am
« Reply #1 on: November 28, 2007, 04:26:46 am »
the switch to ULSD & biodiesel will eventually lead to pump leakage if the pump was never re-sealed.  pumps after '96-ish should have the correct seals to accomodate the new fuels.
the pump should last nearly forever if you change your fuel filter every 6 months or at least a year.  but that doesn't mean the pump won't run like crap after a while...  if the feed pump gets worn out, you can always use a lift pump to squeeze extra miles from it.
Reply #2November 28, 2007, 07:49:45 pm
Leumas
  • 9
« Reply #2 on: November 28, 2007, 07:49:45 pm »
Where can someone get a pump resealed?
Can you do it yourself? How?
