Author Topic: tdi engine code.....Which one?  (Read 5792 times)
October 31, 2007, 05:23:29 pm
SMOKEYDUB
  • 630
« on: October 31, 2007, 05:23:29 pm »
what engine code will a 2004 jetta tdi have?
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1November 01, 2007, 02:40:50 pm
HermTDI
  • 27
04 TDI eng code
« Reply #1 on: November 01, 2007, 02:40:50 pm »
The 2004 Jetta TDI will have engine code "BEW"
Reply #2November 01, 2007, 04:03:27 pm
SMOKEYDUB
  • 630
« Reply #2 on: November 01, 2007, 04:03:27 pm »
thanks alot man
(courtesy of GILES)
Reply #3November 02, 2007, 05:47:57 am
Tintin
  • 1279
« Reply #3 on: November 02, 2007, 05:47:57 am »
BEW and BRM
Reply #4November 02, 2007, 07:59:16 pm
SMOKEYDUB
  • 630
« Reply #4 on: November 02, 2007, 07:59:16 pm »
do they both run the same timing belt?
(courtesy of GILES)
Reply #5November 02, 2007, 08:41:46 pm
Tintin
  • 1279
« Reply #5 on: November 02, 2007, 08:41:46 pm »
Excuse me, I think that the BRM is from 2005.5 only.
Reply #6November 03, 2007, 02:34:32 am
Ziptar
  • 565
« Reply #6 on: November 03, 2007, 02:34:32 am »
BEW Is the First Pump Dusse engine is it not? If you want an engine that uses a Bosch VE ALH is what you need, they only go to 2003.5 though.
Reply #7November 03, 2007, 01:41:16 pm
BleachedBora
  • Administrator
  • 104
    • Cascade German Parts
« Reply #7 on: November 03, 2007, 01:41:16 pm »
BEW is the first PD engine, 2004-2005 on the MK4 chassis. The BRM is the MKV chassis. Both use a Continental timing belt with part number 038 109 119 P which is rated for 100,000 miles.
ALH engines of course are 1998 NB-2003 Golf/Jetta/NB, those take a Gates or Dayco TB PN: 038 109 119 M. Cars before 2003 had different belts, but all will take the "M". As long as you use all the updated rollers and belts all ALH belt changes can be every 100k.
Cheers,
-BB
'81 CBEA Caddy, '81 DeLorean, '98 Defender TDI, Too many VAG to list
www.cascadegerman.com
Sales and support: [email protected]
Reply #8November 03, 2007, 04:38:24 pm
Ziptar
  • 565
« Reply #8 on: November 03, 2007, 04:38:24 pm »
mmmm.. 100K Belt Kits... they rock, I can't believe I am due for another one already...
Reply #9November 04, 2007, 06:52:58 pm
BleachedBora
  • Administrator
  • 104
« Reply #9 on: November 04, 2007, 06:52:58 pm »
I do have kits available that are more complete and have more OEM or OEM+ parts than anyone else I know of...Let me know if you're interested :).
