Author Topic: 1.6/1.9 interchangeability  (Read 2872 times)
March 06, 2005, 02:47:58 pm
foxracer1
  • 991
« on: March 06, 2005, 02:47:58 pm »
Is it possible to put a 1.9 crank in a 1.6? that would give about 107 ci's and 1800 cc's. Also longer stroke promotes better tourqe at lower rpms.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #1March 06, 2005, 06:08:22 pm
vwmike
  • 1158
Re: 1.6/1.9 interchangeability
« Reply #1 on: March 06, 2005, 06:08:22 pm »
Quote from: "foxracer1"
What about rods and pistons? The 1.6 pistons would protrude from the block a tad more than usual with the 1.9 crank (in other words it won't work). The 1.9 has a taller deck height and longer rods with a higher pin height on the pistons from everything I've heard.
Reply #2March 07, 2005, 08:13:19 pm
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #2 on: March 07, 2005, 08:13:19 pm »
If you were to increase a 1.6 to a 1.8 giving it a longer stroke, then the pistons would have to protrude way too far above the block.  The piston-to-valve clearances in these engines are pretty tight.  I can't imagine that it would work.
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #3March 08, 2005, 10:20:45 am
Patrick
  • 1034
« Reply #3 on: March 08, 2005, 10:20:45 am »
Lots of companies make pistons and/or piston/rod combinations to do this with chevy (400 crank in a 350 block, bored 30 over gives 383). Maybe someone does the same for this combo?
Reply #4March 30, 2005, 09:35:49 am
foxracer1
  • 991
« Reply #4 on: March 30, 2005, 09:35:49 am »
I'm sorry i should have said it differently. I didn't figure the factory pistons would work but are the crank specs the same?
91 S10 305 TPI T56
