Author Topic: Cracks by Inserts  (Read 2424 times)
October 23, 2007, 10:44:23 am
TPW
  • 113
Cracks by Inserts
« on: October 23, 2007, 10:44:23 am »
I cleaned off the turbo diesel head for a little work and besides the usual cracks between the valves there are some small cracks by the prechamber inserts.  Are these normal too?  What causes them?
Reply #1October 23, 2007, 11:54:17 am
rabbitman
  • 2788
Cracks by Inserts
« Reply #1 on: October 23, 2007, 11:54:17 am »
when I got my rabbit out of the junkyard I took the head off and it had the same cracks your talking about, probly would've worked but I got on ebay and bought another one anyways.
Reply #2October 23, 2007, 03:13:03 pm
subsonic
  • 1836
Cracks by Inserts
« Reply #2 on: October 23, 2007, 03:13:03 pm »
Where exactly are the cracks?  Between the valves is normal.  Small cracks on the face of the insert happen, not the geatest thing but not horrible.  Cracks elsewhere on the face of the head are not good.
Reply #3October 23, 2007, 07:58:38 pm
TPW
  • 113
Cracks by Inserts
« Reply #3 on: October 23, 2007, 07:58:38 pm »
They are very small cracks on the face of the head 1/8 inch long right next to the insert (two of them). The guy helping me rebuild the head thinks they're just minor stress cracks like the ones between the valves.
Reply #4October 24, 2007, 07:15:32 pm
rabfan
  • 28
Cracks by Inserts
« Reply #4 on: October 24, 2007, 07:15:32 pm »
As far as I know, in my limited knowledge, cracks anywhere other than between the valves are bad. My head has a crack from the valve to the prechamber insert. There is a water jacket right under that point and the crack has propagated into that water jacket. Once I get a replacement head the plan is to cut that one up to see how thick the metal is.
RJ
Reply #5November 01, 2007, 07:58:17 pm
TPW
  • 113
Cracks by Inserts
« Reply #5 on: November 01, 2007, 07:58:17 pm »
I sent this head to a head rebuilder-welder today, hopefully he can weld the cracks closed.  How hard of a process is it to remove and replace the inserts (at a good machine shop)?
