Author Topic: just turned 32,000 running straight veg oil  (Read 2953 times)
October 22, 2007, 06:12:02 pm
uss sterett cg31
  • 7
« on: October 22, 2007, 06:12:02 pm »
been running waste veg oil for three years now through ohio winters no problems yet at 32,000 miles 1985 idi turbo diesel 87 gas jetta body. it was just an experiment made my system all out of copper tubing brazed together. just bought a 98 tdi ahu anybody have any input with vegging a tdi
Reply #1October 23, 2007, 12:02:09 pm
« Reply #1 on: October 23, 2007, 12:02:09 pm »
did your mileage improve w/ veggie oil? So veggie oil is corrosive to fuel lines? I've though of running veggie oil in my rabbit but here in alaska it wouldn't make much sense 'cause 7-8 months out of the year it's to cold for veggie oil.
Reply #2October 23, 2007, 01:53:17 pm
carrizog60
  • 978
« Reply #2 on: October 23, 2007, 01:53:17 pm »
no SVO on tdi engines as the system is not prepare to deal with such a a thick fuel...
Portugal
Reply #3October 23, 2007, 03:27:51 pm
uss sterett cg31
  • 7
« Reply #3 on: October 23, 2007, 03:27:51 pm »
my mileage stayed the same, dont know about veg being corrosive, I ran my system all winter as low as 5deg f any lower I chose not to. During the lower temps I just had to warm up longer I used modified heated filters at 10 micron wix 33125 they last me 1500 mile each.
Reply #4October 23, 2007, 03:55:48 pm
« Reply #4 on: October 23, 2007, 03:55:48 pm »
i know someone running on veg with absolutely no problems (about 10'000km's so far or more now..)
if you want to try and risk it, just make sure to have the veg pre-heated before entering the engine.  if not, you'll surely need to replace the pump down the line.
Reply #5October 23, 2007, 06:06:17 pm
uss sterett cg31
  • 7
« Reply #5 on: October 23, 2007, 06:06:17 pm »
I have a heated tank , a spin on 10 micron filter with a heater built on it , a racor 28 micron with a heater under it , 1/2 in copper line brazed full length to a 1/2 inch copper line with engine coolant  from the trunk up to the engine via the interior to concerve heat in the winter. I run a pusher fuel pump right out of the veg tank. I start my veg burn at 160 deg f . I  also have full fuel return lines and an "h" bypass with the return set at  a bleed to circulate veg to get the stagnete oil warm while running the inital diesel . works well
Reply #6October 23, 2007, 10:17:07 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #6 on: October 23, 2007, 10:17:07 pm »
Quote from: "carrizog60"
I haven't tried veg. oil but I did a fair bit of reading back then and it seems safe for VE TDI (risker in a PD TDI). Like others have mentioned, the veg. oil must be heated to lower its viscosity prior to entering the fuel injection system. Last I checked, www.frybrid.com is one of the top-notch veg. oil kits and their diagrams/forum contain useful info that may help DIY guys optimize their homemade kit.
I would run a well-filtered, well-heated, and well-purged kit in a VE TDI without worrying much. I'm not going to even bother trying it in my new PD TDI though.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
