Author Topic: 1.6TD fitment in a mk1  (Read 2914 times)
October 10, 2007, 06:19:30 pm
silvertdi
  • 125
« on: October 10, 2007, 06:19:30 pm »
Is the mk2 1.6TD a direct drop in?  Any modifications to the body, etc?  Thanks.  :)
Reply #1October 11, 2007, 05:48:49 am
Greasecar
  • 126
    • http://www.greasecar.com
« Reply #1 on: October 11, 2007, 05:48:49 am »
The engine mounts are different between the two but not much else.  If you have all the mounts from the MK 1 the should be good.
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #2October 11, 2007, 06:08:02 am
giulianot
  • 146
« Reply #2 on: October 11, 2007, 06:08:02 am »
you will need a mk1 diesel style engine mount that has the ip bracket on it as well.
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #3October 11, 2007, 08:34:06 am
pariah
  • 31
mk1 td
« Reply #3 on: October 11, 2007, 08:34:06 am »
downpipe may need some attention around the shift linkage i had to grind off a small part of the flange to get 2nd and 4th
Reply #4October 11, 2007, 10:13:19 am
« Reply #4 on: October 11, 2007, 10:13:19 am »
also all the coolant sensors/flanges are different as well. Just swap on NA ones from a mk1.
The air box will give you troubles and you will probably have to move the fuel filter.
Reply #5October 11, 2007, 10:39:48 am
BlackTieTD
  • 1512
« Reply #5 on: October 11, 2007, 10:39:48 am »
the parts snags for me were:
- mkI TD downpipe (bought a 2.5" one from passenger performance)
- mkI TD airbox (got one from burn your money)
another thing to consider is fuel filter location. proper spot for mkI TD is right by the downpipe with a heat shield but i did not use that location.
Reply #6October 11, 2007, 07:40:40 pm
silvertdi
  • 125
« Reply #6 on: October 11, 2007, 07:40:40 pm »
Thanks for the info.  Exactly what I needed.  :)
