Author Topic: Air pipe fitting on K14 wastegate????  (Read 3366 times)
October 09, 2007, 01:22:52 pm
regcheeseman
  • 714
« on: October 09, 2007, 01:22:52 pm »
I've just picked up a spare K14
It has a strange mount for a small manifold where the oil feed goes
It also has a pipe union on top of the wastegate vacuum chamber - what is fitted to that?
Reply #1October 09, 2007, 06:16:41 pm
andy2
Re: Air pipe fitting on K14 wastegate????
« Reply #1 on: October 09, 2007, 06:16:41 pm »
This is probably a watercooled turbo so that may explain the first part!
Possibly you are confusing the wastegate's spring adjustment screw in the center of the wastegate for a pipe union??
Reply #2October 11, 2007, 12:40:18 pm
regcheeseman
  • 714
« Reply #2 on: October 11, 2007, 12:40:18 pm »
It's not the same as the watercooled k14 already fitted to my GTD, the flange is totally different.
Nope I'm not! It is a pipe union and it is exactly where you would expect to find the adjustment screw.
The turbo is from an Audi 2.4
Reply #3October 11, 2007, 01:13:25 pm
« Reply #3 on: October 11, 2007, 01:13:25 pm »
Do you have any pictures?
Reply #4October 11, 2007, 08:10:53 pm
rallydiesel
  • 1880
« Reply #4 on: October 11, 2007, 08:10:53 pm »
Maybe some kind of home-made pneumatic boost controller?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5October 24, 2007, 01:37:49 pm
regcheeseman
  • 714
« Reply #5 on: October 24, 2007, 01:37:49 pm »
Indeed I do! this is the flange thing that would cater for either oil feed or return
And this is the air fitting on the wastegate actuator
Reply #6October 24, 2007, 03:23:50 pm
« Reply #6 on: October 24, 2007, 03:23:50 pm »
Quote from: "regcheeseman"
Yes that's the oil feed on some models... a small manifold with the actual oil line bolts to it.
The other line is the boost control line... particularly on Passats I've seen the turbo is off unless you ask for WOT... a microswitch on the throttle turns the turbo on and off pneumatically using booster pump vacumm connected to this fitting.
As I recall:  "open to atmosphere" = on
