Author Topic: 1.6 D Oil pressure/pump problem?  (Read 15444 times)
Reply #15October 08, 2007, 01:27:14 pm
Trimster
  • 74
« Reply #15 on: October 08, 2007, 01:27:14 pm »
Not saying that everything is fine in the sender units area, but prior to replacing them, we could get the oil light to come on at random times. While cruzin' down the freeway, or stopped at idle, flickering sometimes... random all the way. Replaced both and they behave normally. Low oil, they come on. They stay off until the oil pressure drops to 25 lbs, then buzzer and light. I'm wondering if that, the low oil pressure, is what it's reading and reacting normally... as designed. This motor has close to 300K on it.
bob
Bob
'83 Caddy, 1.6 NA Diesel, 5 speed, AC
2- motorcycles, 36' 5th wheel, sailboat, RC airplanes... to many interests, not enough time.
Reply #16October 09, 2007, 05:33:14 pm
bigblockchev
  • 271
oil press woes
« Reply #16 on: October 09, 2007, 05:33:14 pm »
I did the replace oil pump routine last year & it temporarily cured the low oil pressure. but sooner or later I expect the intermediate shaft bearings will have to be done, the rest of the bearings looked ok. As for manuals the Bentley is the best $44 at amazon.com & worth every penny, pretty much everything else is crap in comparison. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #17October 11, 2007, 12:23:45 pm
Trimster
  • 74
« Reply #17 on: October 11, 2007, 12:23:45 pm »
Did the unhook test you suggested. No buzzer and no oil light.
Bob
