Author Topic: What is the best turbo setup?  (Read 2312 times)
September 22, 2007, 08:17:15 pm
silvertdi
  • 125
« on: September 22, 2007, 08:17:15 pm »
I'd like to start sourcing my build.  I don't want a new tdi engine, but I want decent power out of my rabbit.  Definately want a turbo.  :D   What is the ideal setup.  Want something reliable, not too extreme.  Your help is appreciated.  Thanks.  :D
Reply #1September 22, 2007, 10:08:13 pm
rallydiesel
  • 1880
« Reply #1 on: September 22, 2007, 10:08:13 pm »
I think some here would say a VNT15 would be ideal. The problem is you need to do some fabrication or modification becuase the downpipe from the 1.6's doesn't work with the VNT flange and the turbo would be upside down so you need to plumb some more tubing to get to the intake manifold. You also need to construct some type of vane actuator system.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2September 23, 2007, 04:58:47 am
flapjack
  • 283
« Reply #2 on: September 23, 2007, 04:58:47 am »
are you starting with a non-turbo motor?
If you're using stock downpipe from TD  : K14
heres a bunch of threads i keep handy
Turbo poll thread
http://vwdiesel.net/phpBB/viewtopic.php?t=10264
how to get more power from your 1.6TD
http://vwdiesel.net/phpBB/viewtopic.php?t=645
http://vwdiesel.net/phpBB/viewtopic.php?t=1352&highlight=exhaust
good cheap pyrometer
http://vwdiesel.net/phpBB/viewtopic.php?t=4583&highlight=
signature
Reply #3September 23, 2007, 08:43:23 am
silvertdi
  • 125
« Reply #3 on: September 23, 2007, 08:43:23 am »
Currently my rabbit has a NA 1.6.  I want to make it a TD and want to begin searching for the parts.  I've read that I should start off with a TD engine because they have piston squirters.  So I know I'll need that.  Then I figure a 1.9 is better (more displacement  :D ).  Then from there I'm up in the air.  I want to start off using my 4spd tranny to save a little money.  Eventually I'll switch to a 5 spd.
The links to those articles were very good.  Thanks for the info.  Every piece of knowledge helps me out.  Thanks!   :wink:
