Author Topic: important and easy question about the coolant flange...  (Read 2954 times)
August 28, 2007, 05:30:00 pm
mk2vr6
  • 77
« on: August 28, 2007, 05:30:00 pm »
The headgasket let go on my car and I'm ordering a whole bunch of new parts...  timing belt, tensioner, etc...
The coolant flange on the side of the head is cracked and has been leaking slowly for quite some time.  My question is, does the coolant flange have a space for a coolant temp sensor?  I dont have access to the car and I can't remember for the life of me.  I know the 8v gasser does, but I can't recall on the 1.6TD.
The car is a 1992 Jetta 1.6 TD, w/ a/c, if that helps at all.
I called the dealer and when he asked if its the coolant flange on the side of the head, he said there were no sensors and the part is $14.  Is that the right part or am I needing one with a space for a coolant temp sensor?
Let me know, I need the part either tomorrow or the day after!!   :?
Thanks guys.
89 Golf GL VR6T
92 Golf GTI 16v
92 Jetta 1.6D
92 Jetta 1.6TD
Reply #1August 28, 2007, 07:17:40 pm
pariah
  • 31
coolant sensor
« Reply #1 on: August 28, 2007, 07:17:40 pm »
well mine has 2 sensors on that flange the temp gague and the glowplug override
Reply #2August 28, 2007, 07:17:42 pm
rabbit GTI/GTD
  • 58
« Reply #2 on: August 28, 2007, 07:17:42 pm »
My 87 TD has a sensor in the flange on the side of the head
Reply #3August 28, 2007, 08:01:47 pm
mk2vr6
  • 77
« Reply #3 on: August 28, 2007, 08:01:47 pm »
So it seems mine should have a sensor housing in it too...  well, does anyone have any ideas as to where I could order this part?  I have been looking for it everywhere, no one seems to have it, but plenty of people have it for sale without any sensor housings...
89 Golf GL VR6T
92 Golf GTI 16v
92 Jetta 1.6D
92 Jetta 1.6TD
Reply #4August 29, 2007, 01:11:34 pm
johnboy
  • 45
« Reply #4 on: August 29, 2007, 01:11:34 pm »
The part number will be on the old flange, it should be 9 digit with maybe a letter or two after.
If you cant find it PM me your chassis number, Ill try to get you the correct part number to order from your VW dealer.
Also of note is that some of the earlier water flanges where superseded by VW and will sometimes need a blanking plug to cap off any extra sensor holes. Give the part number you find to your dealer and they should be able to see if there is a supersesion.
(If your dealer is crap PM me the info!)
'96 Passat Estate AAZ.
Standard engine, 1.6Td boost pin, no EGR More boost, more fuel
Intercooler to fit next!!
Reply #5August 29, 2007, 01:21:33 pm
johnboy
  • 45
« Reply #5 on: August 29, 2007, 01:21:33 pm »
Quote from: "mk2vr6"
Order them from your dealer, not sure about the supply situation over the pond but here in the UK they are available and are not too expensive. (PM me if you are struggling, I work in a VW trade parts centre).
Reply #6August 29, 2007, 02:43:49 pm
bigblockchev
  • 271
« Reply #6 on: August 29, 2007, 02:43:49 pm »
My 92 jetta 1.6 TD has 2 coolant flanges one faces forward towards the front of the car It has 2 sensors plugged into it. The other coolant flange is on the end of the head it faces the drivers side wheel and has no sensors on it. Hope this helps. Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #7August 29, 2007, 06:47:54 pm
tdi4by
  • 21
« Reply #7 on: August 29, 2007, 06:47:54 pm »
Quote from: "bigblockchev"
That is the same as mine. Get one from http://www.autohausaz.comIt will only be a few dollars :D
1992 1.6 ECO with a TD pump. T-3 .48ar,
GTD Nozzles-I'm lovin it!!!, 47MPG mixed driving last tank.
2006 CRD Jeep Liberty with some stuff.....
Only 23MPG's..
Reply #8August 29, 2007, 07:45:41 pm
Black Smokin' Diesel
  • 656
« Reply #8 on: August 29, 2007, 07:45:41 pm »
Got any junkyard with some old VW in it? If so, get there and grab the aluminum coolant flanges off early MK2 cars (and grab an aluminum thermostat housing too). They're a good upgrade for peace of mind and they'll last forever. VW cheaped out on later MK2 and they all got plastic flanges prone to failure.
