General Information
Upgrades (non engine related )
Mk2 Trailer hitch
Topic: Mk2 Trailer hitch (Read 9145 times)
August 13, 2007, 03:53:06 pm
subsonic
Mk2 Trailer hitch
August 13, 2007, 03:53:06 pm »
Does one exist? Who makes them, and does anyone know what the hitch / car is rated to tow? Sure would be nice to be able to bring some things with me and not have to wreck the inside of the vehicle.
Kind of makes it messy and hard to load the car after a good day deer hunting :lol:
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
August 13, 2007, 08:36:15 pm
Mk2 Trailer hitch
August 13, 2007, 08:36:15 pm »
I have one and so does my friend. Mine might be home made but I think my friends is a "hidden hitch"
August 13, 2007, 09:31:26 pm
subsonic
Mk2 Trailer hitch
August 13, 2007, 09:31:26 pm »
I went through the hidden hitch web site, no luck 1984 through 92.
I have seen some MK2's with hitches before :? . Are all of these home made??
August 13, 2007, 09:58:10 pm
Mk2 Trailer hitch
August 13, 2007, 09:58:10 pm »
I'll try and get a model number or something off my friends. The owners manual should have the towing capacity
August 14, 2007, 04:16:54 am
Jetta Fan
Mk2 Trailer hitch
August 14, 2007, 04:16:54 am »
I had a class I hitch on my 90 Jetta years ago. It was Reese I think. As a class I hitch, it was rated to tow 2000lbs. I can't remember what the car was rated to tow. Worked well for my little utility trailer.
If you can't find it on the Hidden Hitch website, it could be that they don't make them for the car anymore.
I'm going to be searching for one for my 97 and if I come across a listing for a mkII, I'll post it here.
1997 Jetta 1.9TD AAZ
August 14, 2007, 06:33:52 am
clbanman
Cambridge, Ontario
Mk2 Trailer hitch
August 14, 2007, 06:33:52 am »
http://www.humphreystrailerhitch.com/volkswagen-receiver-hitches.htm
Calvin
91 VW Golf 1.6NA 5spd
August 16, 2007, 11:26:10 am
subsonic
Mk2 Trailer hitch
August 16, 2007, 11:26:10 am »
I did not see one listed for the 85 golf. I am guessing that the Jetta one is a direct swap. Yes?
August 16, 2007, 12:14:49 pm
Mk2 Trailer hitch
August 16, 2007, 12:14:49 pm »
I have a Hidden Hitch for my big-bumpered MK2 and a Hitches-for-Less one for my small-bumpered MK2:
http://hitches4less.stores.yahoo.net/19voljetdraw.html
Couldn't find the Hidden Hitch on their site when I last checked... got mine second-hand.
August 16, 2007, 12:22:27 pm
subsonic
Mk2 Trailer hitch
August 16, 2007, 12:22:27 pm »
Success!
I just found a place that has multiple hitches for the VW's.
http://www.hitch-web.com/default.asp
They seem to be very specific. Different hitch even between the 2 and 4 door 85 golf.
They said that the hitch capacity design was not so much based on pulling power or rear suspension, but on stopping ability. This of course based off STOCK infromation.
For my vehicle they listed the bolt on at about $140.00
150lbs tongue weight
1500lbs towing
something like a 1" receiver
They also offered a HD weld on hitch. $275 shipped Cali to Maine.
200lb tongue weight
2000lb towing
1 1/4" receiver
That sounds much better. Kind of pricey though. They said it gets welded to portions of the rear lift points, plus additional areas. The rep told me it takes his guys about two hours to get all the under coating and such off the underside where the welding needs to take place.
He also said that problems could arise with routing the stock exhaust past the hitch.
Might be more hassle than its worth to get the better hitch. Than again, going to 130+ HP with the 1.6TD takes some doing as well. Have to think about this one. :?
August 17, 2007, 07:57:35 pm
subsonic
Mk2 Trailer hitch
August 17, 2007, 07:57:35 pm »
Any of you guys ever use a weld on unit on your vw?
November 21, 2007, 04:55:52 am
somolovitch3
Mk2 Trailer hitch
November 21, 2007, 04:55:52 am »
Get a chunk of 4" x 1/4" angle iron about 6 to 8 inches long, have shop weld in a 6" of trailer hitch stock. Bolt to bumper. Use the 2" or the 1" receiver. Remember to remove hitch when not in use, save your shins! :twisted:
Ugly, yes. Works, yes as well.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #11
November 29, 2007, 04:59:15 pm
Wolfsbur
User+
Mk2 Trailer hitch
Reply #11 on:
November 29, 2007, 04:59:15 pm »
Subsonic
I purchased a hitch from these guys few years ago--here is the page.
http://www.partsplaceinc.com/catalog/P%20Catalog%202006/index.htm
Then select Page 35 from the side menu
Mine has held up nicely--I think I paid 55 for it, plus shipping. They have used units as well.
Geoff
VR6 93 Passat
1.8 89 Jetta
1.6 TD 83 Jetta
2.0 95 Golf
Reply #12
November 30, 2007, 04:04:57 pm
subsonic
Mk2 Trailer hitch
Reply #12 on:
November 30, 2007, 04:04:57 pm »
Will a trailer hitch act as a rear sway bar? I am guessing that it would stiffen up the rear quite a bit. :?
Reply #13
November 30, 2007, 09:30:03 pm
Mk2 Trailer hitch
Reply #13 on:
November 30, 2007, 09:30:03 pm »
It's not attatched to the rear beam so I don't see how it would be. The last 3 cars I bought all have trailer hitches. I'm rather excited about that. Mind you the last one was just bolted through the trunk floor :roll: yeah it split the floor
General Information
Mk2 Trailer hitch
