R&R combustion prechambers
Topic: R&R combustion prechambers (Read 7954 times)
July 15, 2007, 10:05:27 pm
jolotter
July 15, 2007, 10:05:27 pm »
Has anyone replaced combustion prechambers? My 1.6TD has 2 or 3 cracks in in each one. I don't have replacements yet, but the look like they pull straight out. Anyone have a photo of a tool to do this?
83.5 Vanagon soon to be equipped with
1990 1.6 TD engine
93 Golf 1.9TD and spare engine/tranny
July 16, 2007, 09:30:53 am
Turbinepowered
July 16, 2007, 09:30:53 am »
Bentley manual, at least the Quantum and Dasher manuals, show them being tapped out with a drift pin and a rubber-type mallet, pin inserted through the injector hole.
I would suggest not slamming it hard.
July 16, 2007, 11:50:54 am
July 16, 2007, 11:50:54 am »
I've also heard of machine shops welding a rod to the chamber (from the underside) and using a slide hammer. I would imagine installing the new ones would be as simple as pressing them back in but I have no idea.
'86 Golf N/A Diesel -->Wife's car
July 16, 2007, 02:25:44 pm
July 16, 2007, 02:25:44 pm »
some pre cups come out pretty easy too. the ones in my rabbit i could just blow air into them underneath and they would lift up
July 16, 2007, 02:44:10 pm
Black Smokin' Diesel
July 16, 2007, 02:44:10 pm »
I used a flathead screwdriver through the injector hole and lightly hammered them out. Some come out easy while others are really stuck.
July 31, 2007, 09:14:42 pm
jolotter
July 31, 2007, 09:14:42 pm »
Anyonw know where I can buy prechambers? 1.6 td.
1990 1.6 TD engine
August 02, 2007, 09:06:52 pm
jolotter
August 02, 2007, 09:06:52 pm »
I've just been looking at some photos on this forum, and I see other heads with cracked prechambers like mine. Are they replaced at rebuilds if they're cracked? Do they get blown to bits and fall into the cylinders?
This is the worst of the four
http://s208.photobucket.com/albums/bb15/fonorono/?action=view¤t=IMG_0180.jpg
1990 1.6 TD engine
August 03, 2007, 09:18:33 pm
itzdshtz
August 03, 2007, 09:18:33 pm »
You can get them here:
http://www.emm-motoren.de/eshop/08-vorkammern/volkswagen/index.html
They show all the oversizes too.
Herman
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
August 04, 2007, 07:56:51 am
subsonic
August 04, 2007, 07:56:51 am »
I tried to use the google translator but had no luck. What do you mean by the oversizes? Do you mean a oversize precup? I thought they were all one size (For each engine of course). :?
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
August 04, 2007, 11:04:36 am
itzdshtz
August 04, 2007, 11:04:36 am »
The pre-combustion chambers come in oversizes because when the engine rebuilders overhaul a cylinder head it often happens that the pre-chambers are loose in there, so they remachine the bore of the chamber.
You see this too on original exchange heads from VW, so make sure that you measure your old ones before you buy new ones.
I have not seen any standard sizes here, so measure!
Is says in German that they come as a set, the type that VW uses is: A and then the bore diameter, height and the opening size of the channel that goes to the combustion chamber.
I have measured some of mine that I had laying around and there are quite a few different sizes. On one set, the diameter D actually tapers from 27.17mm down to 26.57mm. It looks like it was pressed into place and deformed.
I have not ordered anything from this company yet but I would like to. If you do, let me know how it worked out.
Herman
1997 Audi A6
1985 Audi 5000 Td
August 05, 2007, 09:11:16 pm
jolotter
August 05, 2007, 09:11:16 pm »
I looked at that german site. My prechambers are 30.5mm so I guess that i would need this one:
http://www.emm-motoren.de/eshop/08-vorkammern/volkswagen/satz-vorkammern-in-510-uebermass-masse-3050.html
There's a VW place in Michigan called PartsPlace that lists a prechamber for "All diesels '77-92 and 1.9 diesels '93-99" for $20.
Unfortunately when I talked to them they said they don't ship to Canada. Maybe I'll try again.
Did anyone look at my picture a few posts up? I can't seem to get it to display on the page, only the link. :(
How bad are those cracks?
Why won't the image post???
1990 1.6 TD engine
Reply #11
August 06, 2007, 07:32:11 am
subsonic
Reply #11 on:
August 06, 2007, 07:32:11 am »
So do you need to pull your lower insert and measure it before you order new ones? I am guessing that I just need the lower half of the insert. Are you guys talking about removing the tophalf that is up in the head ?
Reply #12
August 06, 2007, 09:43:57 am
itzdshtz
Reply #12 on:
August 06, 2007, 09:43:57 am »
Yes, that looks right, now if your head has been resurfaced before, the new pre-chamber will stick out a bit, as 4.30mm is the size it comes in.
You probably have to have the head resurfaced again to get it flat.
Looking at your picture, I think that I would replace that set.
Herman
1997 Audi A6
1985 Audi 5000 Td
Reply #13
August 06, 2007, 06:42:07 pm
jolotter
Reply #13 on:
August 06, 2007, 06:42:07 pm »
Thanks Herman, I'll try that PartsPlace again tomorrow. Maybe I'll have to get one of My Detroit friends to carry it across to one of me Windsor friends.
Any other known North American sources?
1990 1.6 TD engine
Reply #14
August 06, 2007, 09:15:54 pm
itzdshtz
Reply #14 on:
August 06, 2007, 09:15:54 pm »
You're welcome, I have not found any here in North America, but I have been trying to contact two in Poland, one has a listing that shows all diesel applications but the Email link doesn't work, the other makes custom pre-combustion chambers, (I was thinking about special ones so that you can use a 1.9 cyl head on a 1.6, without the cold start problems) but he never Emails back. They probably don't speak English.
I have tried a translation with Babelfish but I have no idea if it is even close to what I want to ask.
Maybe some one on this forum has a Polish background.
Anyhow, here are the links:
http://www.moto-szlif.pl/wirowe_de.htm
Well, I cant't find that second link right now, I will get back when I do.
Herman
1997 Audi A6
1985 Audi 5000 Td
