Author Topic: R&R combustion prechambers  (Read 8275 times)
Reply #15August 06, 2007, 11:34:34 pm
zaprzal
  • 160
    • turbodiesel.pl
« Reply #15 on: August 06, 2007, 11:34:34 pm »
If you need help, send me PM ;)
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #16August 07, 2007, 12:03:24 am
itzdshtz
  • 94
« Reply #16 on: August 07, 2007, 12:03:24 am »
Hey cool zaprzal!
 I just found the link:
http://www.polok.pl/en/products.html
I was wondering if they could make modified pre-combustion chamber inserts for a 1.9TD head that reduces the volume, to that of the the 1.6TD pre-combustion chamber.
This so that the Franken engine will run better when cold, it will also allow me to use a 2.4 TD head on my Audi 2.0 TD engine in my Syncro.
   Herman
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #17August 07, 2007, 12:44:35 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #17 on: August 07, 2007, 12:44:35 am »
I called them. They can do custom external dimension pre-combustion chambers but they can't change internal dimension... They have some shape and thay can't change it  :(
you have to send me some picture and dimensions what you exacly want to do and I'll try to get some more informations
isn't 2,4 head 6 cylinder and 2.0 5cyl.?
Reply #18August 07, 2007, 04:34:34 am
Audi80
« Reply #18 on: August 07, 2007, 04:34:34 am »
There is 2,4 5 cyl diesels in Audi, but not TD.
Reply #19August 07, 2007, 06:49:06 pm
itzdshtz
  • 94
« Reply #19 on: August 07, 2007, 06:49:06 pm »
Thanks zaprzal for your effort, I will have to get hold of a 1.9TD cylinder head to measure how many CC's the complete pre-chamber holds compared with the 1.6TD.
Maybe there are pre-chambers around from other diesel engines that could easely be converted, I'll look into it a bit deeper when I have more time.
   Thanks again,   Herman
1997 Audi A6
1985 Audi 5000 Td
Reply #20August 08, 2007, 12:38:28 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #20 on: August 08, 2007, 12:38:28 am »
ok, just send me PM as you get all informations
