According to what I've read a Giles Pump alone should get you darn close to what you want and no turbo needed.
perhaps the piston cooling jets are just a band aid for a crappy exhaust diameter on the original TD engines.
I've used arp vw watercooled 11mm headstuds before, they work great. Just keep an eye on egts and you don't need to coat the pistons. As said upgrading the downpipe, exhaust, air intake etc, anything to increase airflow will help gain power and lower egt.
Quote from: "Turbinepowered"I like the idea of the smaller displacement engine for a lower baseline fuel consumptionI'm glad you like the idea, but I don't know how accurate it is. Certainly different engines have different baseline engine efficiencies, but I'm not under the impression that with regard to diesels that engine efficiency is necessarily displacement related. Please correct me if I'm wrong, but because diesels can run infinitely lean and have no throttle, the only downside to increased displacement (given all other factors remaining the same) is that there might be more reciprocating mass or even more weight to carry around. There is not the same fuel economy detriment that is present with gas engines which require a stoichiometric mixture. Basically if a diesel is rotating faster than necessary all fuel can be cut (free-flowing air pump) and at idle the only fuel required is enough to keep it rotating. If a larger displacement diesel is driven at the same acceleration rates as a smaller displacement diesel the vehicle gets the same fuel economy. It's only when someone takes advantage of the added horsepower/torque that is present with larger displacement, that there is a fuel economy detriment. If you want to decrease your fuel consumption it's easier to either demonstrate self-control or turn down the max fuel on a larger displacement motor than it is to swap motors IMO.Andrew
