Author Topic: 1.5 Potential...  (Read 15526 times)
Reply #30March 20, 2007, 12:18:01 pm
addautomotive
1.5 Potential...
« Reply #30 on: March 20, 2007, 12:18:01 pm »
Quote from: "addautomotive"
Question for the 1.5 netsperts:
If the 1.5 & 1.6 bore is the same, can a 1.6 TD block be used with 1.5 crank & pistons to build up a proper 1.5td?
Looks like I found my answer:
http://www.vwdieselparts.com/forum/viewtopic.php?t=6190
Quote from: "Diesel Dean"
Anybody made this swap 1.5 internal parts into a 1.6 block??
Thanks Dean
Quote from: "Fatmobile"
Yes, there have been a few people who over the last couple years have  put 1.5 internals in a 1.6 block and let us know about it.
 I've been thinking about this setup with a turbo. It does provide better fuel economy and I've wondered if an eco turboed 1.5 could give hagar a run for his money in the search for high smileage.... and help provide a little more needed power.... it might be a good setup with the stronger 1.6 block wrapped around it.
Reply #31March 20, 2007, 09:34:35 pm
Turbinepowered
  • 1206
1.5 Potential...
« Reply #31 on: March 20, 2007, 09:34:35 pm »
Now there's an idea... make a real, honest 1.5TD.
Now I have a project for the next turboblock I find. Then I'll probably do something crazy, like stick it in an old Beetle or Ghia.  :lol:
Reply #32March 21, 2007, 11:45:18 am
addautomotive
1.5 Potential...
« Reply #32 on: March 21, 2007, 11:45:18 am »
Quote from: "Turbinepowered"
Or Porsche 914. Mid engined, so the additional weight wouldn't ruin the handling. Plus, there are plenty of cooling setup precedents, because of the chev V8 swaps.
Ya, not that I've thought about this or anything....
Reply #33August 11, 2007, 08:44:00 am
Ziptar
  • 565
1.5 Potential...
« Reply #33 on: August 11, 2007, 08:44:00 am »
This thread has me wondering..
If I wanted the highest possible MPG while interstate cruising.. Which would be the way to go?
1.6TD Eco
1.5TD Made from a 1.6 TD Block, 1.5 Crank & Pistons, Eco IP (No LDA 8MM Plunger) Eco injectors, K14.
1.9 TDI-M Stock 10MM IP, .184 Injectors (auto TDI) K14.
1.5 - 1.6 N/A That is made to breathe well, maybe use 8MM IP
In other words... What is more efficient for constant highway load with occasional passing? i sit so small between them all that it's moot??
Reply #34August 11, 2007, 07:18:33 pm
Turbinepowered
  • 1206
1.5 Potential...
« Reply #34 on: August 11, 2007, 07:18:33 pm »
Yeah, but the old VWs are much, much cheaper to acquire. :D
Reply #35August 12, 2007, 10:50:31 am
935racer
1.5 Potential...
« Reply #35 on: August 12, 2007, 10:50:31 am »
1.6TD Eco
TDI-M will get better fuel economy, use a t3 turbo though.
Reply #36August 12, 2007, 12:01:40 pm
1.5 Potential...
« Reply #36 on: August 12, 2007, 12:01:40 pm »
1.6td hydro block, 1.5 internals, 1.9 head, and a pump built to rev... it'd be an interesting setup.  i wonder how it would compare to a 1.7td with a 1.9 head.  someone needs to start building these frankensteins.  if i had the shat i''d go for it haha.
Reply #37August 12, 2007, 12:35:37 pm
Audi80
1.5 Potential...
« Reply #37 on: August 12, 2007, 12:35:37 pm »
I´ve got 1,9 block, 1,6 crank, 1,9 NA pistons, modded 1,6 mech head and high revving 12mm pump :D
Reply #38August 12, 2007, 12:40:32 pm
1.5 Potential...
« Reply #38 on: August 12, 2007, 12:40:32 pm »
why the 1.6 head?  and did u need custom rods?  haha and i know ur motor performs.
Reply #39August 12, 2007, 12:56:52 pm
Audi80
1.5 Potential...
« Reply #39 on: August 12, 2007, 12:56:52 pm »
I wanted to use 1,9 head, but got no money for it now :( So I used what I already got. And yes, custom fitted Nascar Carrillo rods 8)
