Author Topic: 1.6 TD Oil pressure light and no vacuum at start up (sometimes)  (Read 8499 times)
July 20, 2021, 02:30:24 pm
33B
  • 58
    Bosnian with a money pit aka VW Passat 1987
Sometimes at start up i get oil pressure light and no vacuum (stiff brake pedal), and if i rev it oil pressure light goes off and i get vacuum (soft brake pedal), after that I have no problems. Can be days or weeks before it happens again. So is the intermediate shaft getting stuck somehow or?
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
Reply #1July 20, 2021, 05:29:05 pm
srgtlord
  • 797
Re: 1.6 TD Oil pressure light and no vacuum at start up (sometimes)
« Reply #1 on: July 20, 2021, 05:29:05 pm »
Have you checked the seals on the vacuum pump?
Reply #2July 20, 2021, 09:55:51 pm
  • 2924
« Reply #2 on: July 20, 2021, 09:55:51 pm »
 Diaphram style vacuum pump?
If so:
Pull it off and see if the gear is wearing into the brass thrust bushing in the bottom of the vacuum pump.
« Last Edit: July 20, 2021, 10:11:05 pm by fatmobile »
Reply #3July 21, 2021, 03:04:03 am
33B
  • 58
« Reply #3 on: July 21, 2021, 03:04:03 am »
It's a new type vac pump with plastic fins.
I have just replaced it a few days ago because one way valve failed, but the problem with oil pressure light didn't change.
Reply #4July 21, 2021, 05:36:27 am
Ohiobenz
  • 77
« Reply #4 on: July 21, 2021, 05:36:27 am »
The intermediate shaft is driven off the back of the timing belt by a smooth pulley.
Possibly a) the belt has too much slack or b) there's oil on the belt.
Either way I'd pull the upper timing cover and take a look.
'88 Suzuki Samurai with '85 1.6 TD
K14 turbo
BOV eliminated
Giles performance built IP
Reply #5July 21, 2021, 06:08:08 am
33B
  • 58
« Reply #5 on: July 21, 2021, 06:08:08 am »
Yes sir. I had that same thought process. I checked the belt it is tight also there was some gunk on it cleaned it up. But didn't change a thing.
Now that I'm thinking about it, it takes a few seconds to pull vacuum. Maybe im just being paranoid when the oil light comes up and thinking that vacuum also doesnt work.
So if my problem goes away with just revving the engine a little bit and than I have no problems for a few days can it be that oil pressure sensor is bad.
I looked at the sensor that's on the oil filter housing it's white. And on the back of the head is BLACK???? Shouldn't it be blue? Is that the old type?
Also the engine was NA old style mechanical head. Code is idk just a set of numbers and a VW logo and some 3 circles in a triangle. I turboed it, exhaust, intake manifold, valve cover, oil filter housing, oil cooler, oil pan. KKK K24
The car was originally 1.6td but someone in the 90s swapped it for this engine. Wiring is all still there, so the high pressure oil sensor is connected and working
« Last Edit: July 21, 2021, 06:23:34 am by 33B »
Reply #6July 21, 2021, 11:34:24 am
« Reply #6 on: July 21, 2021, 11:34:24 am »
Sounds like completely typical symptoms of a somewhat worn and out-of-spec oil pump that takes a while to prime if it has drained enough to lose its prime.  Without oil, the vane style vac pump will not work.  Because of the loose oil pump clearance, revving it is required to finally get the pump to prime itself.  It then pumps oil to the vac pump and your brake vacuum assist works.  Simple as that.
Reply #7July 21, 2021, 11:40:48 am
33B
  • 58
« Reply #7 on: July 21, 2021, 11:40:48 am »
Thanks for clearing this up for me.
What to look for when buying a used oil pump? Where do I look for play?
Also can i put a bigger gear diameter oil pump (from hydro engine) in my engine ?
Reply #8July 21, 2021, 04:35:42 pm
« Reply #8 on: July 21, 2021, 04:35:42 pm »
I wouldn't bother with a used oil pump.  They are readily available new.  Be sure to get a quality brand.
The gears of the various pumps are not larger/smaller in diameter.  The gears are taller/shorter.  36mm tall gears are the largest and used with the hydraulic lifter+turbo engines.
Reply #9August 02, 2021, 03:37:21 pm
33B
  • 58
« Reply #9 on: August 02, 2021, 03:37:21 pm »
Interesting....
Mine takes 3 seconds to get vacuum ,would a new oil pump be instant then?
I'll be replacing mine tomorrow. I'll get you the update on that.
Reply #10August 03, 2021, 08:10:02 am
« Reply #10 on: August 03, 2021, 08:10:02 am »
With a new pump it is still a good idea to measure the clearance between the top of the gears and the pump lid.  A bit of plastigage works well for that.  The limit is 0.006.  If it is near there, then you can hand lap the pump body to remove material so the lid moves closer to the gears.  That can make a big difference in whether or not the pump loses prime or how long it takes to build pressure.
Reply #11August 03, 2021, 05:18:04 pm
33B
  • 58
« Reply #11 on: August 03, 2021, 05:18:04 pm »
I've intalled a good used oil pump from 1.6td (quantum/passat cy i think) that i have for parts. Definitely an improvement regarding how quickly i get vacuum. It's not instant but maybe after 1 or 2 sec.
The old pump was jamming when spinning by hand. Good thing i replaced it on time.
Reply #12August 03, 2021, 09:33:42 pm
  • 2924
« Reply #12 on: August 03, 2021, 09:33:42 pm »
There is a seal inside the gear on the vacuum pump.
 Make sure yours is there.
It seals around the oil pump shaft.
Reply #13August 04, 2021, 04:54:45 am
33B
  • 58
« Reply #13 on: August 04, 2021, 04:54:45 am »
It's there, I've installed a new vac pump.
Problem was the oil pump.
Thanks
Reply #14August 04, 2021, 01:52:04 pm
« Reply #14 on: August 04, 2021, 01:52:04 pm »
The 1.6TD Quantum CY engine was solid lifter and used the pump with 30mm gears.  If your engine has hydraulic lifters and a turbo/oil jets, then you should use the pump with 36mm tall gears.
