Author Topic: 1.6 TD Oil pressure light and no vacuum at start up (sometimes)  (Read 8940 times)
Reply #15August 05, 2021, 02:14:35 pm
33B
  • 58
    Bosnian with a money pit aka VW Passat 1987
Re: 1.6 TD Oil pressure light and no vacuum at start up (sometimes)
« Reply #15 on: August 05, 2021, 02:14:35 pm »
Thanks for the info. It's a turboed NA with mech lifters, no oil jets. The oil pump is bigger then the original one that i removed.
https://ibb.co/W29QkWB
https://ibb.co/bbKkNkF
« Last Edit: August 05, 2021, 02:16:31 pm by 33B »
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
Reply #16August 05, 2021, 02:35:13 pm
« Reply #16 on: August 05, 2021, 02:35:13 pm »
If you don't have the hydro lifters or oil jets then the 30mm pump is fine.
Reply #17August 05, 2021, 07:46:11 pm
  • 4553
« Reply #17 on: August 05, 2021, 07:46:11 pm »
What?  30mm is fine?  Bigger is always better.  Well unless it is a bill to the electric co.
