Author Topic: where do you mk3 td guys put you IC  (Read 6226 times)
August 25, 2004, 05:00:39 pm
optiks
  • 31
« on: August 25, 2004, 05:00:39 pm »
i have a mx6 intercooler and cant fit it anywhere in my '97 1.9 TD
Reply #1August 25, 2004, 08:01:44 pm
Cheesetoast
  • 285
« Reply #1 on: August 25, 2004, 08:01:44 pm »
the stock mk3 tdi intercooler is mounted on the driver side under the bettery there.  see what u can do.
Reply #2August 25, 2004, 08:13:14 pm
optiks
  • 31
« Reply #2 on: August 25, 2004, 08:13:14 pm »
nope not enough room, the oem one must be tiny
and its mounted on the pass side BTW
Reply #3August 25, 2004, 08:35:49 pm
QuickTD
  • 1156
« Reply #3 on: August 25, 2004, 08:35:49 pm »
The OEM TDI IC is about 8" x 8" and lives in the left front fender. Air is fed to it by the vent in the front valence. One of these would be the easiest install, most of the piping could be used as well. I opted for a different install. Here is a thread with pics of my installation. http://vwdiesel.net/phpBB/viewtopic.php?t=220&highlight= I used a saab core, about 8" x 8", the end tanks are custom, as is everything else.
Reply #4August 26, 2004, 07:38:06 am
BlackTieTD
  • 1512
« Reply #4 on: August 26, 2004, 07:38:06 am »
QuickTDs install is nice.
do you have AC? if so... do you need to keep it?
Reply #5August 26, 2004, 09:59:51 am
AntonUK
« Reply #5 on: August 26, 2004, 09:59:51 am »
Hey has anyone seen Smog's IC install? He managed to mount it in front the rad (without AC) but when I looked at installing my Merc Vito IC I couldnt see how I could run the pipes to it as the whole front member is one big plastic mould with the rad and fan built into it and has not got a lot of gaps. Pics of his install...
http://forums.tdiclub.com/showflat.php?Cat=&Number=540773&page=0&view=collapsed&sb=5&o=14&fpart=all&vc=1
I would really like to intall something like this but my front end looks different to Smog's. :?
Reply #6August 26, 2004, 07:12:45 pm
gropar
  • 49
1.9 IDI,
minimalist exhaust system; soon big FMIC and 15 psi boost.
Reply #7August 26, 2004, 07:22:46 pm
QuickTD
  • 1156
« Reply #7 on: August 26, 2004, 07:22:46 pm »
Yours is different than smog's. The north american rad support is steel, the european rad support is plastic. Have a look at http://www.dieselmeken.se, click on the "Golf III" link. He has a front mount on a european golf. Looks like he just sawed through the plastic rad support to make way for the piping...
Check the "films" while you're there. Impressive stuff for a 1.9TD. I have exchanged e-mails with the owner. No power adders were used to obtain those 1/4 mile times, all diesel!
Reply #8August 26, 2004, 07:33:43 pm
QuickTD
  • 1156
« Reply #8 on: August 26, 2004, 07:33:43 pm »
Zounds, thats a huge IC, Gropar. That must be the volvo one I've heard about. Seems a shame to only run 15psi through that, you should aim higher!
You might try hosting that pic somewhere else though. As it stands, only TDIclub members can view it.
Reply #9August 26, 2004, 10:56:13 pm
Cheesetoast
  • 285
« Reply #9 on: August 26, 2004, 10:56:13 pm »
copy the link and paste it in a new window instead of clicking on it.  This also works for image station and a few others.
Quote from: "QuickTD"
Reply #10August 27, 2004, 01:51:19 pm
AntonUK
« Reply #10 on: August 27, 2004, 01:51:19 pm »
Damn Euros!..Thought I could see bent metal on Smogs but not on mine. Looks like the American version is easyer to work with.
One thing I noticed on Dieselmenken's Golf is the intake manifold. The elbow which lives ontop of the manifold seems to be blocked off and the boost pipe seems to be entering the manifold at the side of it?? not very clear from the pictures though. Looks intresting anyway.
Has anyones thought about using Subaru Impreza's Charge cooler? Its mounted above the engine in OEM position and has minimal boost piping. Its also cooled via a bonnet scoop but Im more intrested in its air-to-water capability. there are two versions, the WRX and STI, even though they look the same Im sure the STI is uprated??
Anyways just rambling.
Reply #11September 01, 2004, 11:10:13 pm
1985JettaTD
« Reply #11 on: September 01, 2004, 11:10:13 pm »
Gropar: is your IC off off a volvo? i have one that looks just like yours that i would love to get on my 1985 Jetta 1.6TD. did you have to move the rad back at all? what kind of monts did you use? and how do you have the charge pipes running? what body is yours on? more inform about your install would to awsome!!!
thanks for everything
Reply #12September 02, 2004, 05:33:00 am
gropar
  • 49
« Reply #12 on: September 02, 2004, 05:33:00 am »
Yes, the intercooler comes from Volvo.
To fit it in, I had to move the rad a little. I just bent the original brakets a little longer.
I had to cut all of the rad support that went lower than the bumper, the I screwed the top of the intercooler to the rad  support. The lower part of the IC holds with two aluminium brakets screwed to tje metal bumper.
As for the piping... :oops:  it's not done yet. I had to do lots of other things in order to keep the car working, so the IC job got delayed.
Intend on making custom piping with rad hoses on the driverside and to use custom bent exaust piping on the passenger side (to go around all straps and pulleys) in order to save a few(alot!) bucks. One day, if I get rich  :roll:  I might go for mandrel bent / welded piping...
As I said in a previous post, I intend on using 15psi boost, but with the replies I got, I now think of 18 or 20. But I'm not so shure : it is a daily driver and I want to keep it reliable, and for a long time...
1.9 IDI,
