Author Topic: MK3 GTD  (Read 10464 times)
Reply #30May 26, 2006, 01:56:35 pm
Otis2
  • 191
MK3 GTD
« Reply #30 on: May 26, 2006, 01:56:35 pm »
So nozzles are fitted :D
There is much more smoke :D But I'm not sure that there is pretty much difference  :roll:
Maybe near the red line car is faster  :twisted:
That's a strange result.  Other threads have suggested that GTD injectors actually reduce the smoke, even if they don't do much to improve power.
You may need to retard your timing slightly, to account for the greater volume of fuel being injected in the same "time window" as your old injectors.
Also, you may need to crank down the main fuel screw, too, if you've turned it up already.
There is actually a fair amount of contradictory information on this forum about the GTD injectors.  I haven't seen much in the way of objective measurement of the GTD-injector-swap results, just a lot of "butt dyno" comments.  I'm still on the fence, but would love to be convinced.
Reply #31May 30, 2006, 09:28:13 pm
akrallysport
MK3 GTD
« Reply #31 on: May 30, 2006, 09:28:13 pm »
Sveicieni no Kanadas!  :) Ja ir kadi jautajumi, nebaidies man prasit, itseviški ja dažreiz nesaproti anglu vardus. Varu palidzet ar teknisko valodu... var jau atrast daudz informaciju šeit, bet jamak meklet.
Cheers,
Andris
p.s. Pats nopirku savu pirmo Vento ar AAZ dizeli. Ja gribi, varu nofotografet lai vari salidzinat turbo. Jau esmu iesacis speleties ar 'modding', bet pa priekšu ar riteniem, riepam, atsperem, u.t.t. Novelu labu laimi ar interkuleri... man jau bijis prata kopš nopirku savejo. ;) Vai nevareji atrast G60 interkuleri? Domaju, ka deret labak...  8)
Reply #32June 01, 2006, 04:44:19 am
envy
  • 19
MK3 GTD
« Reply #32 on: June 01, 2006, 04:44:19 am »
heh...
Sveiks! :)
Nu principaa mana mashiiniite vizuaali mani jau apmierina ;)
p.s. Riepas, atsperes, amortizatori - DONE! :D
Te ir kaada bilde:
Ko esmu jau paspeejis ar motoru???
Ir GTD sidzinaataaji, ir degvielas padeve max, cik vareeju, ir BOOST meeriitaajs, taa kaa tagad celshu spiedienu, shodien buus 1.6 TD suuknja BOOST PIN :D
Taalaak seko interkuulers un taisnaa truba, jo man veel joproajaam ir katalizators  :oops:  par G60 kuuleri.... man liekas, ka tas ir par mazu  :P
par turbo zinu tikai to, ka ir KKK, un Braalja GOLFam turbiina ir mazaaka! ;)
domaaju, ka tev buus interesanti ;) www.vwmotion.lv  :twisted:
TDI PD ~150HP & 380Nm
Reply #33July 05, 2006, 05:48:01 am
envy
  • 19
MK3 GTD
« Reply #33 on: July 05, 2006, 05:48:01 am »
So!
I have done everything I wanted! And my GTD is sold!
I have bought new toy Mk4 TDI PD engine 115hp and 285 Nm! :)
so last drag pics!
2.0 GTI
1.9 TDI 90Hp
I'm proud of fact, that my GTD will be driven by my good friend! ;)
 8)
