Author Topic: 1.6Block to a 1.9Head question plus a few more.  (Read 5879 times)
October 16, 2012, 05:04:27 pm
Hoble
  • 76
« on: October 16, 2012, 05:04:27 pm »
Ive done some creeping on this side but never posted anything. This isn't the forum Im overly active on. I have become die hard diesel guy over the past year and a half and am now building a rather.... interesting project. the car itself is a secret other than the fact its a mk2. the motor however, is not. 1.6 block, 1.9 head, bored (more for good fitment than for power as you cant really bore them out to much) new 1.9 head from overland, Dr diesel cam, water meth, Giles built bigger injectors, compound turbos (K03 from a 1.9 and a larger T3. 50 trim with a .48 ar) and to feed this a Giles pump tuned for 35 psi. holding it all together are ARP head studs, main studs and rod bolts. Also getting rodsten rods i believe they are called.
I am just starting this build but have the majority of the parts needed but i still have some questions.
the more people i ask about the 1.6/1.9 combo, the more different answers i get. I have a hydro 1.6 block and (ordering) a 1.9 head. Can i just slap these two together and it work fine? Ive been told i have to drill coolant hols into the block? some say i don't have to though?
I also have a few questions about the head. I shouldn't be revving this motor to high, only 6g tops, but i would like to upgrade the valves/ valve springs as i'll be running 35 psi. what do you recommend?/ where do i get it?
I want a girdle for this as well but don't know where to get one? or am i going to have to make it?
I have started looking into oil baffles as well and heard the 1Y ones are the best. whats the difference?
Thats it for now, but there will be more coming as this is my first true performance build
Thanks, Lee
Reply #1October 16, 2012, 10:45:36 pm
Powered by Spearco
  • 1203
Re: 1.6Block to a 1.9Head question plus a few more.
« Reply #1 on: October 16, 2012, 10:45:36 pm »
The hydro 1.6L block will except the 1.9L head when using a metal multi-layer head gasket, recommended. I drilled the coolant holes in the block to allow for even coolant transfer between the two. I guess you could leave them , but why not do it?
I'm using Tectonics Tuning HiRev dual valve springs and have yet to float a valve or hold one open.
Oil baffles. I've got a 16V oil pan windage tray in conjunction with the oil pump pickup tube baffle. Whats the 1Y baffle?
Good luck with your project.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #2October 17, 2012, 02:44:03 am
Hoble
  • 76
« Reply #2 on: October 17, 2012, 02:44:03 am »
Ok. Do the coolant holes just go straight down into a coolant void or do they need to be angled?
The 1y is a 1.9 diesel motor. Possibly na.
Reply #3October 17, 2012, 04:39:45 am
justiz00
  • 54
« Reply #3 on: October 17, 2012, 04:39:45 am »
I have the CAD drawings for the girdle and the 10 main cap spacers. I had a 1/4" girdle waterjet cut last week for mine, now I am thinking of going 3/8" or thicker. PM me your email and I will send you the files. They are both in .dxf format.
Justice
Reply #4October 17, 2012, 06:19:22 am
« Reply #4 on: October 17, 2012, 06:19:22 am »
There are programs available or a good machinist should have on calculating valve springs. 35psi isn't much especially on stock diameter valves. I wouldn't think you would need any kind of upgrade there, you want your springs to close but you don't want any extra spring pressure if you do not need it...unless you don't care about extra drag on you performance. Many on here have ran stock springs up to 40psi and haven't had valve clash, so I would think you really don't even need to search for the valve spring calculator to do figuring, but if you want a for sure answer then start hunting.
Now if you were to increase the valves diameter and ran that much pressure then you have a need for springs. Or if these could spin 11k then yes an upgrade is in order.
Reply #5October 17, 2012, 09:33:33 am
justiz00
  • 54
« Reply #5 on: October 17, 2012, 09:33:33 am »
You have mail Hoble.
Reply #6October 17, 2012, 12:59:06 pm
Hoble
  • 76
« Reply #6 on: October 17, 2012, 12:59:06 pm »
I saw that thanks. I'm about to talk to the water jet guy at work so ill let ya know man.
As for the valve springs, I am going to be tracking the car so I figured it would be a good upgrade to have. Do they actually create more drag?
Reply #7October 17, 2012, 04:53:36 pm
« Reply #7 on: October 17, 2012, 04:53:36 pm »
More wear and drag on the cam. You only want as much spring as you need, this is one of the only places I have seen that you do not want overkill
Reply #8October 17, 2012, 04:56:00 pm
« Reply #8 on: October 17, 2012, 04:56:00 pm »
The heads valve springs are good for more RPM's than the pump will be able to spin. I see no reason to upgrade the valve springs.
Reply #9October 17, 2012, 06:57:12 pm
Hoble
  • 76
« Reply #9 on: October 17, 2012, 06:57:12 pm »
ok fair deal. saves me from taking apart a brand new head, minus the cam swap. as of noon today i dropped the block off to get bored out and the crank to drop some of that extra weight.
on the same note as the cam, i was thinking of doinf a lightweight flywheel, although ive heard its a bad idea on a diesel. makes them sound like death at idle. any input? (im running a hydro tranny. possibly a 6 speed vr)
Reply #10October 17, 2012, 07:49:05 pm
« Reply #10 on: October 17, 2012, 07:49:05 pm »
If it will be a Gasser flywheel, it will likely be lighter stock than a diesel one.
Reply #11October 17, 2012, 07:56:35 pm
Hoble
  • 76
« Reply #11 on: October 17, 2012, 07:56:35 pm »
i mean like running a ten pound flywheel. a "G60" setup
Reply #12October 18, 2012, 03:57:03 am
« Reply #12 on: October 18, 2012, 03:57:03 am »
IIRC anything under 8lbs is the starting of where the diesel has rough idle.
Reply #13October 18, 2012, 06:17:52 am
Hoble
  • 76
« Reply #13 on: October 18, 2012, 06:17:52 am »
Alright perfect. Back to the head to block. If I do drill holes then do they go into coolant passages or do I have to angle them or what?
Reply #14October 18, 2012, 02:24:16 pm
« Reply #14 on: October 18, 2012, 02:24:16 pm »
VR trans has the wrong bell housing for a TDI...
